mm turning 21 was good, my insurance premium has dropped by $600 for my next year :) but my agreed value has dropped $2k :)
it wouldn't be cause you turned 21 that your insurance dropped its because the agreed value has dropped
.7
you generally wouldnt need to go any lower
Damo - that logic test, 1 of the questions i didnt like was #5
Answer 5.
a) Where there is poverty there is crime.
b) There is crime in Camberwell.
- Therefore there must be poverty in Camberwell.
Invalid. There may be crime where there is poverty, but it does not necessarily follow that wherever crime is there is poverty. There is plenty of crime occurring in wealthier circles.
where there is poverty there is crime is a truth statement its not guessing
there is crime in camberwell is again a truth statement
so how can it be invalid where not discussing how wealthy camberwell is just stating there is crime there
sweet..can they go lower due splitfires?
Ideally want a higher gap not a lower. I higher gap gives a better ignition to the fuel but it also is weaker spark which makes it susceptible to being "blown out" by the intake charge.
Anyhow the accepted gap is 0.8mm if you have split fires then you should be able to run a bigger gap but it'll be trial and error to find out how big and I wouldn't go over 1>1.1mm anyway.
Edited by D_Stirls
hmmm.... ok i think there at .8 atm... thats wat they are from the box?
i can just feel the car hold back constantly then be ok the hold back due to missing...
ill open them up more... trial and error i guess..
what is the last number on the part number? If it had some thing like BKPR6ES-8 then it is 0.8 but if it was -11 or didn't have a number at the end then it's 1.1mm
If you are having spark problem then opening them up won't help you need to close them up, but if you have split fires then you shouldn't be having spark problems. you will know if they are breaking down because it'll sound like it not running on all cylinders where as you are saying it's feeling like it's being held back which isn't spark. It's probably got more to do with ignition timing.
Edited by D_Stirls
Surely dropping my agreed value from 23,900 to 21,850 wont bring my insurance premium from 2098 p/a to 1500 p/a. if thats the case, ill set agreed value at 18k and pay no insurance.
Rhys, yep just car, got the info from my policy renewal letter, expires early Feb.
Guest
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
