20" vault chromies at the front and black steelies at the rears... massive street cred increase right there :yes:
FS: set of Steelies. Comes with 2 extra if you're going to bust out huge skids and want to keep that line going down the street.
Unknown offset... but when they're ablaze, it doesn't matter.
:cool:
:cool:
I typed in Commodore Steelies and Commodore Stockies and Commodore Skids and this is what it came up with:
Look at that first picture of the Commo ripping it up... notice how the passenger is wearing a helmet, but the driver isn't? What a fail! Maybe the passenger window is open and he's wearing the helmet to protect his head when the tyres burst and rubber fly's through the window :yes:
:cool:
On another forum I saw some modified steelies with monster dish on a Rolla,... looked phat
that could be another option for the 32 .... would be different
SOLD MY NINJA 250R on my way to buy a 2006 yamaha R1 50th anniversary edition woohoooooooooo
Is that the yellow one in traditional yamaha colours? if so they look very nice! but i don't like the way R1's ride.
If anyone wants a set of steelies i have a set of 16x7.5 ~+35 5x114.3 that i'll let go for $30 each or or $100 for the whole set (and i'll throw in the plastic hub caps). They'd be perfect for drifting as they would be easy to straighten and who really cares for $30, or for some rep' points on the street.
Edited by D_Stirls
im being told fully bored out rb25 rehousing with hi flowed internal will make close to 300rwkw..
anyone else think this could happen? i didnt think the 25 turbo is big enough even after being bored out
Yeah it probably could but would cost you a packed to do it properly
I have 2 x standard GTR turbos that are steel wheels and my car make 300kws on 16psi of boost
Adrian, who told you that?
I had a what you call a 'bored out' rb25 rear with larger steel wheel with my gt2871r and it was on the limit at 250, hence why i bought the new turbo.
Guest
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
