im being told fully bored out rb25 rehousing with hi flowed internal will make close to 300rwkw..
anyone else think this could happen? i didnt think the 25 turbo is big enough even after being bored out
yes this is true Bill at ATS does a 3076 high flow job to the RB25 he claims on bp98 he's had them upto 270rwkw and on E85 over 300
alot of people see those figures and think woooow! he claims he can get 300 out of this turbo wow....that's on 28psi and a f*kn shoe string tune just to get the numbers up there....by all means get an undersized, push the envolope turbo if you will....I'm awaiting some thread titles like...'why is my rb25 missfiring' 'someone help me with my rb25' and my favourite 'best place to get a rebuild'. Choose wisely the first time if your concerned about reliability.
No craig, i havne't driven my car in a week. hehe
Edited by Ryanrb25
I'm not having a go chris, im just having an opinion on something...I've had those turbo's and seen this shit man, on other peoples car's aswell....just giving you some info not from 'what ive read or just been told'. Not gonna lead anyone in the wrong direction.
Edited by Ryanrb25
steve are you talking about a gt30 with a machined out rb25 exhaust housing???
if you are they are f**kEN CRAP and waste of time !!!!!!!!...they defiently will only push 270rwkw
a workshop put this on my car and then blew the motor not long after on the dyno
Anyone know what a reasonable ballpark figure I'd be looking at to get two stockie 32 gtr turbos converted to steel exhaust turbines...?
I can buy some blown turbos but last quote I got for a rebuild (from an anonymous source) wanted $1250 per turbo.... for that price I can possibly get a pair of proper N1's....
MTQ and ATS get mentioned a bit, I haven't called them (usually because whenever I'm thinking about turbos its night time and theyre closed)... have any of ya'll had this done? How much did it cost you?
-D
Edited by Dohmar
It may well be possible to flow it through it...just maybe, but it would be very unsafe.
I asked my partner and he is a mechanic and said exactly what you said :D
Best you would get out of it would be 260/270kws and the boost would be up there.
R33 Chris why are you thinking that option for turbo?
Guest
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
