any1 giving away a 2 seater lounge??? wanna put 1 in my room, just bought the new HP touch screen computer n everything is wireless (mouse, keyboard) so i dont have to sit at a bloody desk all the time
from memory there we some seats in the for sale thread (dw just checked they were yours :ermm::P
hello everyone
Ok just got back from Dyno. Boost controller having trouble holding boost as it spikes to 25psi and by the end its at 19.5psi.
1st Run wheel spun its titties off so Pete had to tighten the straps more (made 279)
2nd run right up the top off the torque range it lost traction again and the graph fell away (made 323.8)
3rd run the heat had set in but still managed 323.2 and still wheel spun a touch up the top of the torque.
If i can get the boost to hold more stable who knows possible. I will post the dyno graph in the RB25 upgrade thread sometime today.
I owe all this to AD (aka180or200)who has done an absolutely brilliant job on tuning my car. Your a legend mate.
Needless to say i'm stoked with the outcome.
yea and we got one person to thank for it.
Niel is only doing his job....if you have a defectable car then you run the risk of being picked up....it's simple....we have regulations there for a reason and if your car isn't within those regs then pay the price to get it fixed.
Thats one reason why I've removed the mod stuff from my Stagea. Even the exhaust which has a big muffler and tip is very quiet for its size. I took it to the exhaust shop 3 times until I was happy with its noise level. Still got the cat in it too, and fitted a larger resonator, even has a new O2 sensor to ensure its running clean. My car looks great with the body kit and thats about all I need right now. I have my bikes and track days if I wanna go fast.
Getting the silver S1 Stagea registered soon now I've replaced the waterpump, O2 sensor and timing belt. Engine and gearbox has been serviced. I'll be driving that around next month when the black S2 Stagea's rego runs out. The silver stagea is as stock as they come. I can't sell it, so I might as well drive it.
Edited by RubyRS4
Guest
    • Regardless, its peace of mind swapping the factory twins for something else. Personally if it was me: Link G4X Additional sensors for engine protection Twins Oil pump mods(maybe throw extension to sump) injectors/Pump Clutch Exhaust Oil Cooler Good pads/suspension Should be good for 3-350kw depending. Granted thats closer to 15k but still.
    • I think you are over thinking it again
    • My R33 never ran more than stock boost but it was unclear whether the turbos would last. Maybe OP's car is less of a question mark but for my stock turbos had over 175k km on them + 25 years of use. That's a very long time to hope nobody has ever accidentally put physical shock through them, no debris in the exhaust gas stream, no boost leaks that could cause the compressor to spin faster than it otherwise should, no oil coking in the journals, no wear scars for any reason, etc. You could pull the turbos and disassemble to inspect/overhaul as needed but for that kind of effort you may as well replace the ceramic turbine with something that can take a bit more abuse no matter what you find in there. Stock boost ceramic turbos really don't make that much power either.
    • A Pillar forward?   The part above I was just looking at was the reo bar, I'd replace it, UNLESS the panel beater is GOOD. From your early photos, it did look like the chassis might be tweaked, or at the very least there was tweaks in radiator support. I'd personally do a new / second hand unmolested reo bar, and drill it, only so I know underneath the pretty painted front bar, there's not a mess of other metal that's been hit and smacked.
    • Yes no yes. Pineapple rings do do a certain amount of subframe "locking up", in that they do add some resistance to lateral movements. But the primary reason they exist is to alter the driveline angle. Depending on how you install them you can either increase or decrease rear traction __ a little bit __ by changing the angle of the lower control arms relative to the car/pinion angle. The thing is, given what they are, how and where they are installed, their lack of engagement with anything in particular, there's a limit to how much benefit they can offer. The GKTech collars put metal into the space in the stock format bushes, thereby limiting how much give they have. The rubber is still there to take up some force, albeit perhaps preloaded a little by having some extra metal jammed up into it, but the increase in stiffness comes from making it so that the stock format bush can't deflect that large bit of rubber over into the space adjacent to it, in any direction. Top AND bottom. Which the pineapples certainly do not do. As I said in my other thread - I'm convinced.
