nice as cruizin, youd be cheerin.
I was so cheering all day been looking for a xf ute but come across this on ebay and the owner was champ he bought a new battery for it before i picked it up cost him 120 and he dident charge me and she drives like a new car plus i know the 4.1efi engines like the back of my hand
Yep. Skids. Big ones. And lots of em. And continually be thrashed like a $2 hanson road special.
And when she breaks, RB25DE goes in.
be nice there not that cheap and nasty they have standards lol cant wait to see some of them "skids"
And that falcon is clean as!
25 owns 20, simple as that....:(
driven many different combinations with both motors.
25 has more pro than con in comparison
hey, its no redtop ryan hahahahaha
yes
silvertop owns NICS redtop anyday
i rememeber my massive 79kw on 5psi from that motor
56t gt2871r
10psi at 2400rpm
210rwkw on 8psi with 10.1afr's
Hey Ryan, with 10.1 afr's you should tie a bucket to your zorst and recycle the fuel thats pouring out.
210rwkw could go up another 20 or 30 if you pulled some fuel out. :domokun:
Guest
    • Thanks mate 👍 The car was brought into the UK by a USAF mechanic until he was stationed back to the US, one owner later I bought her back in 2009. Luckily the only corrosion was on the sill seams, so once taken back to metal and treated and sealed all ok, I then undersealed the car myself and check yearly and treat any corrosion which to be honest is zero. She's garaged most of the time and hardly ever driven in the rain, but as you say most are rotten unfortunately, I was lucky in finding her as she was and still is in excellent condition.
    • Stunning car.  Looks amazing!  You're in the UK?  How the hell do you stop your car rotting away beneath you?  British cars are the WORST I've ever seen in regards to rust.  Some of the cars SR Autobody have done are borderbeyond saving.
    • not a date code? or a foundry code?
    • I have up to date pics of the engine build and turbo conversion over on my instagram @skpro_jects if you want to take a deeper look.   Basically the exhaust manifold is straight bolt on and the ports match (they arent any smaller than a 25 or 26 head).    the intake ports are different shape so the 20/25det manifold will bolt up but wont match properly or seal. You will need to port match using the 25det gasket as a stencil. Personally i ran the entire stock 20neo intake setup and have configured the swirl valves and torque valve to work based on my custom parameters to help with off boost response and spool. But this is using a standalone aem v2 ecu. The stock 20det ecu wont be able to control them.
    • Hi. a little later but if the topic is here. So...the exhaust is the same and you can use 25/Turbo or any aftermarket? What about intake side? Is it too "plug n play" or? (i do not remember for 100% but i think that one intake to head gasket was little bit different than on the RB25 - i bought gasket kit way back) I know that even if it "plug" those butterfly swirls would cause ECU to be confused or?   Just asking for the info 🙂 and of course the RB25 things are easier to come by
