well some weird stuff is goin on with the GTR. I suspect its the battery causing it.
Took car to auto electrician this morning - turns out it was the fusible link that had corroded. Dude at the auto leccy replaced it and added two bigger terminals to fit my optima battery. Can't wait to pick it up.... total cost is around the $100 mark too, which is great (considering I was worried that the entire car's electrics had died).
Bonza
-D
wheres the australian breeds like a dingo lol ( support australia) jks
I used to have a blue heeler x border collie.
Smartest dog i've ever owned... Very loyal, best security guard, bloody champion!
only pic i have here at work - cant see it too clearly, but here she is next to the 33 back in the day:
nice dogs there penny.
this is our staffy sassy (original ownwer called her ''asassin'' wtf?)
this is her just now sulking coz im to sick to take her fore a walk lol
good news dohmar! glad to hear its all sorted.
Think my spark plugs f**ked itself. Coming onto boost it feels like its choking, chuck it into neutral and idles roughly for a few seconds then is fine again. It still drives fine; until boost comes on. Damn spark plugs, what a pain it is to remove it.
Yeah that would be a smart dog. We have 2, a Kelpie x Border Collie and a purebred Labrador..
The Labrador is bloody dumb. As in so stupid I think it actually is retarded. Its fat and lazy, always wants food and hogs all the affection.
The Kelpie cross is smart, but obsessed with chasing tennis balls. Shes a brilliant guard dog tho, barks at everyone that passes by and cuts sick if they try and get inside the yard. Every skyline should come with one imho...
-D
Guest
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
