anyone know of a bluebird or datsun club in aust?
there website?
http://ozdat.com/ozdatonline/
:rofl:
Been a member there for about 10 years now :D
Check out my supercharged SR20DE 200B wagon :(
Edited by RubyRS4
I know i get a bit shirty all the time about things but doesnt any one google any more gts lets just ask my online buddies and ill see what answers i get
i also understand its good to ask as i didn't know about ozdat but it seems people dont even look any more and just want to be spoon fed :(
boy its hot today
actually steve i did google and i found datsun club of south australia... but that wasnt much help.
and i few various other sites, so then i asked and found exactly wat i wanted..
did it kill u to read it in the wasteland??? would u like me to start a new thread?
thanks ruby..
yep, hot. Trains today are shit, little to no air con in the carriage i was on :(
public transport in general is shite in hot weather. and the govt wonders why people still drive to work. perhaps its because u dont wanna smell like the inside of a gym when u get to work (unless u work in a gym, apologies to personal trainers out there)
-D
boosting the stag yesterday, beaut tune from boost werx.
feels unreal, even with all that heatsoak the engine is so strong!
kudos to to the Slide turbo bush-bearing "stage-2" highflow, really really reliable & strong even with 46deg tarmac heat ..... nice
so happy with my stagea now. really is a nice drive :(
learned so much from this site, pity these days there arnt too many in-depth threads.
nah im quite happy with my current one! hooked on fishing and crabbing now tho :( haha
hehe im goin fishing weekend after next. hopefully get some snappers ... crabbing sounds interesting damo, are u using nets from the jetty or dab nets ?
-D
Guest
    • Or get a guy in his early fiftys to do it. A single good "oof" and about two cracks from his lower back is about the right tightness...
    • It's impossible to convey what it will feel like to get the right torque. But you can develop a feel for it. A 900mm breaker bar is.....f**king huge. I only use a normal ~400mm one. But with 900mm being very nearly a metre, and the right torque being in the order of 100Nm, then you're going to need a bit over 100N of force, which is about 10 kg. So if you practice using the bar pulling up, instead of pushing down, then it will be about the same effort as lifting a 10kg bucket of water. That's what the pressure against your fingers should feel like. Ish. If you use a more typical length breaker, then it's about twice that. So a good 20 litre bucket, or a little bit more.
    • Also, if anyone has a torque wrench around Williams Landing area and can lend it to me for like 5 mins - I got 4 bottles of Furphy left and I’ll throw that in with a Happy meal 😂
    • So today I decided to bleed my brake fluid, which meant to the wheels came off the car at my garage for the first time. I only had a 90cm breaker bar with me and I noticed that some 1 or 2 lug nuts were a bit hard to get loose (from when the shop did the coilovers) Now.... when it came to putting them back on, I didn't want to put all my weight and overtighten them. So I hand tightened as much as possible and then put normal pressure on the edge of the breaker bar and tightened it until I couldn't turn it anymore without putting in an effort. Do you think that is tight enough? Or is that still too tight?  They are tighter than finger tight. Last thing I want is to have them strip or warp sh*t. But hard times mean I can't just go down to Supercheap and get a torque wrench 🥺
    • Dunno what to tell you, when I look at it on Consult I can see this warmup timing map kicking in around 40C coolant temp and it sticks around for a while:  At part throttle on the normal base timing map it peaks around ~43 degrees of timing or something like that, this warmup timing map drops it to like 12-15 degrees.
