The end of the cricket was bloody awesome - apart from the fact that we lost.
Very exciting game though - never thought we would post such a low total either :sick:
Not liking the cricket is unAustralian and should be against the law. Fair enough test cricket can be a bit slow at times (that what all the beer drinking is for), but the one dayers are all action.
test cricket can be a bit slow at times (that what all the beer drinking is for), but the one dayers have plenty of moments. If you get bored watching Twenty20 then you need some dexxys to treat your add
Fixed :sick:
Cruise was good. Lost the main pack, 'borrowed' Luke ENR-034s map then we went for a nice drive through the hills then I went home. I absolutely love having a stock car, pulled into the meet point car park, looked at the multiple cops at every exit and just laughed :(
they feel good?
So far so good, i haven't had a chance to really test them out but atm its staying very flat through corners and im getting a bit more feedback all round.
what sort of settings can you play with?
Height only, everything else is preset. as far as settings go i cant find any information on these coilovers as they were only ever sold in japan and in limited amounts too apparently... majority sold had spring ratings at 9kg front 7kg back that's about all i know.
Other noticeable feature is a double spring setup, i haven't seen anything like it before. Should have grabbed a few pics before i put them in but heres one I found on the net for an r32 GTR
helper springs. pretty common. they compress completely flat when the car is on the ground and keep the main spring captive when it decompresses.
Edited by scandyflick
i work at a tire store.
yes you do need a wheel alignment your toe, caster and camber need to be adjusted.
not that expensive, and can save your tires.
i disagree if you setup up your ride height to a similar to factory height you wouldn't need and alignment if you say take an inch or 2 out you probably might
cricket and paint are 2 of my favourite things... =P
honestly cricket wont hold my attention for long, but the end of the one dayer was right down to the wire.
certainly much better than tennis
you not ment to sniff it :sick:
tx3_90 - nice looking coils
But its an >ENGLISH< game. Give me Aussie Rules Football for a slice of dinkum australiana
-D
Guest
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
