They also hire via Hays Recruitment. Most government agencies go through Hays as well.
Ring them up or send in your resume to them. Seriously.
They get you a Project Officer, Business Analyst (same shit) or Project Manager job in government in days! And you can name your hourly rate!
Don't be afraid to ask for $30+ an hour, because they pay it!
no - now he has a tyre filled with flammable gas .... great idea
i must've forgot to mention how great of an idea it was in the original post...
I shared something i found, that i thought was interesting. no need for sarcasm
Nah I wasn't having a go at you for a second mate - it is a great vid (I have watched it a few times in the last few hours for giggles).
However, you have to question the intelligence of the clown doing it - I would be uber scared of losing an arm or 2 :wave:
lol dan i meant the 33 in the pic, not your car, i wouldnt dare turn against the midnight blue, i would be burned at the stake lol.
On another note, anyone keen on joining in a track day im organising at mallala? will be a combination of drift and grip, 30 min intervals between each. $300 each, have the track or a full day, booked in for march 26th.
If anyone is interested PM me.
ah man, the 26th is the day i go up to the gold coast!
otherwise i would have joined in on the track day! as much drifting i can get in the better haha.
on private track days do they get rid of those gay tyre's on turn 1 and before the straight?
its an easy way to bead tyres on to wide rims for the stretched look. what wasn't included in the video however is that once the burn is gone you have to quickly jump on to an air line and fill them with air as they suck back in and go off the rim in no time.
have done it before...
Ah. Off to get a haircut. Hate getting it done.
I'm only asking them if they've had a busy day... not their period cycle or anything.
lol they actually get trained to talk your ear off and generally think they are improving your experience.
time to start applying for those project officer position boys
its an easy way to get into the govt even if your on a ASO2 position
at least its something and you can get access to better positions once you have a year or 2 worth of experience in any particular field
Epic shit:
Yeeeeep yep yep yep yep yep yep yep uuuhhhh huh uuuuhhh huh uuuuhhh huh uuuuuhhh huh
Yeah, now you're speaking our language.
[20:13] Dohmar: yepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyep
[20:13] Dohmar: Radio!.
[20:13] Dohmar: UH HUH
[20:13] Cara: yepyepyep
[20:14] Dohmar: Radio.
[20:14] Cara: yepyepyep
[20:14] Dohmar: UH HUH
[20:14] Dohmar: yepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyep
[20:15] Cara: uhuh
[20:15] Dohmar: uhuh
[20:15] Dohmar: Radio.
[20:15] Cara: yepyep
[20:15] Dohmar: yepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyepyep
I hereby accept next years nobel prize on behalf of SAU.
-D
Guest
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
