Hi again guys,
Since I bought by R34 4-door 10 months ago now I've been annoyed by the yellow-ish highbeam out of the standard R34 GT-T headlights. I went down to Repco to ask them about it and they told me they're Xenon highbeam and I'm up for something crazy like $250 a globe to replace these with something a bit whiter.
This seems to conflict with what I've read on the forums about the highbeam on R34 just being regular globes. I've looked as best as I can through the headlight glass as the bulbs and they do look kinda weird - like they have some sort of solid wire that runs to the end of the globe - the Repco guys reckoned that was a clear indicator it wasn't a standard globe but a xenon.
Does anyone know what sort of globes these might be? I've searched both the forums and google and come up with no luck. Ripping apart the headlight assembly to get into the globes to rip them out and take a closer look is a last resort - it looks like a real pain (I sure cant get my hands behind there to replace highbeams without taking out the whole headlight!). I can probably get a pic or two of the globe through the headlight glass if that helps.
So guys - if you have any idea - let me know! :thumbsup:
Jenna
https://www.sau.com.au/forums/topic/188428-r34-highbeam/
Sounds like a hid globe to me. I find it a bit stupid having a hid globe as high beams though. You're not recommended to flash hid globes and when you flash, you use the high beams.
If they are hid globes then they'll cost you quite a bit. Not worth changing it for the looks. Looks that last for like 2 sec if you don't drive in the outback.
https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-3397802
  • 4 weeks later...
yeh the high beams aren't hid the main lights are hid, with my 34 when you hit the high beams it comes up yellow like a normal car light, but they come on and the hid dont turn off so all 4 lights are on, id say just take out the high beams and see if you can get some blue type bulbs for them probably h1's same as r33 id imagine
https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-3458813
  • 2 months later...
Heh, well I finally got convinced someone to rip out the globe on the highbeam to check it out - what can I say - sometimes I don't feel like getting my hands dirty or breaking nails (like I always seem to)... :D
... Anyways, cut a long-story short - looks like they are HID on the highbeam. From what we can see, looks like someone converted the highbeams to HID, installed a ballast, etc - before I even got the car (I'm the first aussie owner). :D
The really crazy thing is - they then installed really crappy 'yellow' HID bulbs. For a car that I bought that was verystock - original exhaust, tape-deck, etc - I didn't think I'd find any modifications at all. Perhaps this is something crazy from compliancing - I ended up with someone elses headlights... who knows
Anyways, I checked out the prices of better colored HID globes and nearly fell over ... $400ish for the pair .. ouch. I think I'm going to have to learn to live with yellowish high-beam :P
Jenna
https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-3567157
man thats tuff. i went to replace my high beams for the same reason, only thing i found was that the phillips manual said tey were h1 but infact the standard r34 high beams are hb3 globes.
if u convert them back, use hb3 crystal vision globes for that white look like m3 bmw.
https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-3567940
  • 4 months later...
Soooo .. to bring a long ago thread back ...
When I was replacing my regular low-beam D2R HIDs today, I thought I'd have a second-look at the high-beams that I originally started this thread about. The connector thingy at the bottom is marked as a 'HIR1', but the rest of the bulb looks like a regular HID with the wire along the side of it n all.
HIR apparently standards for 'Halogen Infrared Reflecting', but all the google searches I've done don't look anything like those sorts of bulbs in the bulb part - but it's that sort of side-wise pointing connector.
HIR Bulb Stuff
Does anyone know whether all R34 highbeam have this HIR type connector, or what? A hit of 'HIR', 'HIR1', 'HIR2' all show nothing when I try the search function.
As always, I'd love everyone else's thoughts :blink:
Jen
Edit: Found a picture of the same sort of bulb online:
https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-3873467
dude, i'm in the same boat as you...
i asked to replaced my high beam globes with whiter ones, got given H1 globes and were told they'd fit perfect, when i went to change them they looked like weird and nothing like what i got sold, exactly how they look in the picture you've posted above...
would appreciate what others have to say in regards to replacing these etc. in a cost efficient way...
seems to me the owner of my GT-T in Japan did what yours did too
https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-3876487
i already told u guys, GET PHILLIPS HB3 CRYSTAL VISION GLOBES... $90 for a pair and they straight swap out with the old ones. they also come with matching white globes for your parkers...
Looking on http://www.philipslighting.com.au/CV.htm they could be the HB3 or HB4.
How do we know there isn't a HID ballast there, and these are some sort of Xenon globe - they sure look xenon to me (and the guy at the shop sure thought they were xenon - holding an actual xenon globe and this globe next to each other they were identical except the plug). Can you run a xenon over a HB3/4 type plug? The globes on that page look like regular halogen type.
Is this the standard plug type for other R34s? Are they delivered from the factory with a HB3/4?
Any other thoughts on how to check things?
Jenna
https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-3885221
lol i got same yellow highbeams.. they dont really do much with these stock blue xenons which came with car.. do yours make a cool scary face aswell :) lol
Nah nothing like that on mine - just annoying yellowness compared to the bright white / blue xenons - they produce great light but eh .. I'm picky :)
Cool "face" you produced on the photo from the glare though! :bunny:
https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-3901454
i get abused sometimes cause of my headlights lol cause people think im driving behind them high beaming, all my mates complain about them to me when i drive behind cause there too bright.. so most probably need to do something about that hey lol. once blown anyway. *cough*
https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-3901618
Jenna
Yep they're not HID...same as what I've got, just a flashy bulb :thumbsup:
https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-3913151
  • 6 months later...
from reading around the net it could be they are a bulb called HIR
they are halogen bulbs with an infrared (H IR) coating on them to make them burn hotter / brighter
google HIR bulb and you will see they look the same (look for a site named candlepower)
https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-4351507
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
