jrm Posted October 8, 2007 Share Posted October 8, 2007 Hi again guys, Since I bought by R34 4-door 10 months ago now I've been annoyed by the yellow-ish highbeam out of the standard R34 GT-T headlights. I went down to Repco to ask them about it and they told me they're Xenon highbeam and I'm up for something crazy like $250 a globe to replace these with something a bit whiter. This seems to conflict with what I've read on the forums about the highbeam on R34 just being regular globes. I've looked as best as I can through the headlight glass as the bulbs and they do look kinda weird - like they have some sort of solid wire that runs to the end of the globe - the Repco guys reckoned that was a clear indicator it wasn't a standard globe but a xenon. Does anyone know what sort of globes these might be? I've searched both the forums and google and come up with no luck. Ripping apart the headlight assembly to get into the globes to rip them out and take a closer look is a last resort - it looks like a real pain (I sure cant get my hands behind there to replace highbeams without taking out the whole headlight!). I can probably get a pic or two of the globe through the headlight glass if that helps. So guys - if you have any idea - let me know! Jenna Link to comment https://www.sau.com.au/forums/topic/188428-r34-highbeam/ Share on other sites More sharing options...
adam-__- Posted October 8, 2007 Share Posted October 8, 2007 Sounds like a hid globe to me. I find it a bit stupid having a hid globe as high beams though. You're not recommended to flash hid globes and when you flash, you use the high beams. If they are hid globes then they'll cost you quite a bit. Not worth changing it for the looks. Looks that last for like 2 sec if you don't drive in the outback. Link to comment https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-3397802 Share on other sites More sharing options...
Auto Group Buy Posted October 12, 2007 Share Posted October 12, 2007 You can get a whole kit for that price :-)..find out the bulb model and let us know..Take a pic but its hard to tell from pic too sometimes.. Link to comment https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-3408280 Share on other sites More sharing options...
adznight Posted November 5, 2007 Share Posted November 5, 2007 The high beams are just standard Halogen and they are always more yellow than the Xenon's. The reason is that the Xenon's take too long to fire up so they use halogen instead. I wouldn't bother changing them as you'll only ever use them in back streets and dark roads etc Link to comment https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-3455270 Share on other sites More sharing options...
s13_Skyline_inside Posted November 6, 2007 Share Posted November 6, 2007 yeh the high beams aren't hid the main lights are hid, with my 34 when you hit the high beams it comes up yellow like a normal car light, but they come on and the hid dont turn off so all 4 lights are on, id say just take out the high beams and see if you can get some blue type bulbs for them probably h1's same as r33 id imagine Link to comment https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-3458813 Share on other sites More sharing options...
jrm Posted January 7, 2008 Author Share Posted January 7, 2008 yeh the high beams aren't hid the main lights are hid, with my 34 when you hit the high beams it comes up yellow like a normal car light, but they come on and the hid dont turn off so all 4 lights are on, id say just take out the high beams and see if you can get some blue type bulbs for them probably h1's same as r33 id imagine Heh, well I finally got convinced someone to rip out the globe on the highbeam to check it out - what can I say - sometimes I don't feel like getting my hands dirty or breaking nails (like I always seem to)... ... Anyways, cut a long-story short - looks like they are HID on the highbeam. From what we can see, looks like someone converted the highbeams to HID, installed a ballast, etc - before I even got the car (I'm the first aussie owner). The really crazy thing is - they then installed really crappy 'yellow' HID bulbs. For a car that I bought that was verystock - original exhaust, tape-deck, etc - I didn't think I'd find any modifications at all. Perhaps this is something crazy from compliancing - I ended up with someone elses headlights... who knows Anyways, I checked out the prices of better colored HID globes and nearly fell over ... $400ish for the pair .. ouch. I think I'm going to have to learn to live with yellowish high-beam Jenna Link to comment https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-3567157 Share on other sites More sharing options...
cheez Posted January 7, 2008 Share Posted January 7, 2008 man thats tuff. i went to replace my high beams for the same reason, only thing i found was that the phillips manual said tey were h1 but infact the standard r34 high beams are hb3 globes. if u convert them back, use hb3 crystal vision globes for that white look like m3 bmw. Link to comment https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-3567940 Share on other sites More sharing options...
jrm Posted May 17, 2008 Author Share Posted May 17, 2008 Soooo .. to bring a long ago thread back ... When I was replacing my regular low-beam D2R HIDs today, I thought I'd have a second-look at the high-beams that I originally started this thread about. The connector thingy at the bottom is marked as a 'HIR1', but the rest of the bulb looks like a regular HID with the wire along the side of it n all. HIR apparently standards for 'Halogen Infrared Reflecting', but all the google searches I've done don't look anything like those sorts of bulbs in the bulb part - but it's that sort of side-wise pointing connector. HIR Bulb Stuff Does anyone know whether all R34 highbeam have this HIR type connector, or what? A hit of 'HIR', 'HIR1', 'HIR2' all show nothing when I try the search function. As always, I'd love everyone else's thoughts Jen Edit: Found a picture of the same sort of bulb online: Link to comment https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-3873467 Share on other sites More sharing options...
hoony Posted May 18, 2008 Share Posted May 18, 2008 dude, i'm in the same boat as you... i asked to replaced my high beam globes with whiter ones, got given H1 globes and were told they'd fit perfect, when i went to change them they looked like weird and nothing like what i got sold, exactly how they look in the picture you've posted above... would appreciate what others have to say in regards to replacing these etc. in a cost efficient way... seems to me the owner of my GT-T in Japan did what yours did too Link to comment https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-3876487 Share on other sites More sharing options...
cheez Posted May 19, 2008 Share Posted May 19, 2008 i already told u guys, GET PHILLIPS HB3 CRYSTAL VISION GLOBES... $90 for a pair and they straight swap out with the old ones. they also come with matching white globes for your parkers... Link to comment https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-3878955 Share on other sites More sharing options...
naomy Posted May 19, 2008 Share Posted May 19, 2008 http://cgi.ebay.com.au/PHILIPS-HALOGEN-Car...1QQcmdZViewItem Link to comment https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-3878997 Share on other sites More sharing options...
jrm Posted May 21, 2008 Author Share Posted May 21, 2008 i already told u guys, GET PHILLIPS HB3 CRYSTAL VISION GLOBES... $90 for a pair and they straight swap out with the old ones. they also come with matching white globes for your parkers... Looking on http://www.philipslighting.com.au/CV.htm they could be the HB3 or HB4. How do we know there isn't a HID ballast there, and these are some sort of Xenon globe - they sure look xenon to me (and the guy at the shop sure thought they were xenon - holding an actual xenon globe and this globe next to each other they were identical except the plug). Can you run a xenon over a HB3/4 type plug? The globes on that page look like regular halogen type. Is this the standard plug type for other R34s? Are they delivered from the factory with a HB3/4? Any other thoughts on how to check things? Jenna Link to comment https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-3885221 Share on other sites More sharing options...
THR34T Posted May 28, 2008 Share Posted May 28, 2008 lol i got same yellow highbeams.. they dont really do much with these stock blue xenons which came with car.. do yours make a cool scary face aswell lol Link to comment https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-3900793 Share on other sites More sharing options...
adam-__- Posted May 28, 2008 Share Posted May 28, 2008 That's a farkin BAD beam of light you've got there man. The WORSE glare I've seen on a skyline. What did you do? You've been blinding on coming traffic, have you had any flashes? Link to comment https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-3900806 Share on other sites More sharing options...
adam-__- Posted May 28, 2008 Share Posted May 28, 2008 Oh shit, just read the thread title again and it says "highbeam" hahah. If that's your high beam pattern then that's still shit. I thought it was low beam pattern for a minute there. Link to comment https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-3900814 Share on other sites More sharing options...
jrm Posted May 28, 2008 Author Share Posted May 28, 2008 lol i got same yellow highbeams.. they dont really do much with these stock blue xenons which came with car.. do yours make a cool scary face aswell lol Nah nothing like that on mine - just annoying yellowness compared to the bright white / blue xenons - they produce great light but eh .. I'm picky Cool "face" you produced on the photo from the glare though! Link to comment https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-3901454 Share on other sites More sharing options...
THR34T Posted May 28, 2008 Share Posted May 28, 2008 i get abused sometimes cause of my headlights lol cause people think im driving behind them high beaming, all my mates complain about them to me when i drive behind cause there too bright.. so most probably need to do something about that hey lol. once blown anyway. *cough* Link to comment https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-3901618 Share on other sites More sharing options...
666DAN Posted June 2, 2008 Share Posted June 2, 2008 Looking on http://www.philipslighting.com.au/CV.htm they could be the HB3 or HB4.How do we know there isn't a HID ballast there, and these are some sort of Xenon globe - they sure look xenon to me (and the guy at the shop sure thought they were xenon - holding an actual xenon globe and this globe next to each other they were identical except the plug). Can you run a xenon over a HB3/4 type plug? The globes on that page look like regular halogen type. Is this the standard plug type for other R34s? Are they delivered from the factory with a HB3/4? Any other thoughts on how to check things? Jenna Yep they're not HID...same as what I've got, just a flashy bulb Link to comment https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-3913151 Share on other sites More sharing options...
ztune_R34 Posted June 7, 2008 Share Posted June 7, 2008 If you want to replace high beam bulb on R34 the Philips HB3 Hallogen bulb is near perfect fit. You'll need to slightly modify the plastic fitting in order to fit it in, 20sec. job and you'll be sweet. I've just done it today. Link to comment https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-3925930 Share on other sites More sharing options...
Haines Posted January 6, 2009 Share Posted January 6, 2009 from reading around the net it could be they are a bulb called HIR they are halogen bulbs with an infrared (H IR) coating on them to make them burn hotter / brighter google HIR bulb and you will see they look the same (look for a site named candlepower) Link to comment https://www.sau.com.au/forums/topic/188428-r34-highbeam/#findComment-4351507 Share on other sites More sharing options...
