hey guys up for sale a r33 nissan skyline series 2. its black in colour and has 127000km. It has a custom one sided cooler and custom piping. t3 hiflow turbo built by mtq. custom dump pump with 3inch exhaust turbo back. retuned computer which was tuned by mrc dyno performance it is making 206.3rwkw with an eboost 2 on 14psi and 214rwkw on 17psi. Also has a bosch 040 fuel pump. Brand new head with cometic head gasket new head bolts and studs done by race solutions.heavy duty clutch. 20inch ame pridors all around with whitewalls. car is in very good and drives awsome. if you want more details call kon 0401283356 cheers. pics on the link below $15500ono
http://www.calaisturbo.com.au/showthread.php?t=119960
Edited by BLESSN
https://www.sau.com.au/forums/topic/188432-r33-series-2/
Hey mate, might be interested, if you could send interior shots and otherside photos and let me know if theres and dints or scratches ect or ne problems. Also can u supply RWC? im in Townsville QLD, n if its all good cond ect i will fly down 2 collect. Cheers
Todd
https://www.sau.com.au/forums/topic/188432-r33-series-2/#findComment-3405952
hey mate no worries will send u the pics. no dints just a few scratches on the front bar and rear bar thats preety much it. getting full detail and new rubber this w/e so price may go up or we can sort sumthing out man...
https://www.sau.com.au/forums/topic/188432-r33-series-2/#findComment-3406264
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
    • That's odd, it works fine here. Try loading it on a different device or browser? It's Jack Phillips JDM, a Skyline wrecker in Victoria. Not the cheapest, but I have found them helpful to find obscure parts in AU. https://jpjdm.com/shop/index.php
    • Yeah. I second all of the above. The only way to see that sort of voltage is if something is generating it as a side effect of being f**ked up. The other thing you could do would be to put a load onto that 30V terminal, something like a brakelamp globe. See if it pulls the voltage away comepletely or if some or all of it stays there while loaded. Will give you something of an idea about how much danger it could cause.
    • I would say, you've got one hell of an underlying issue there. You're saying, coils were fully unplugged, and the fuse to that circuit was unplugged, and you measured 30v? Either something is giving you some WILD EMI, and that's an induced voltage, OR something is managing to backfeed, AND that something has problems. It could be something like the ECU if it takes power from there, and also gets power from another source IF there's an internal issue in the ECU. The way to check would be pull that fuse, unplug the coils, and then probe the ECU pins. However it could be something else doing it. Additionally, if it is something wired in, and that something is pulsing, IE a PWM circuit and it's an inductive load and doesnt have proper flyback protection, that would also do it. A possibility would be if you have something like a PWM fuel pump, it might be giving flyback voltages (dangerous to stuff!). I'd put the circuit back into its "broken" state, confirm the weird voltage is back, and then one by one unplug devices until that voltage disappears. That's a quick way to find an associated device. Otherwise I'd need to look at the wiring diagrams, and then understand any electrical mods done.   But you really should not be seeing the above issue, and really, it's indicating something is failing, and possibly why the fuse blew to begin with.
