I heard the trust type M dont need the fan blades to be cut.. Obviously you will still need to cut a hole for the piping on the side..
Or you could get return type coolers such as ARC.. But will be expensive..
Otherwise most cheap copies, will require you to cut a bit of the fan blades..
https://www.sau.com.au/forums/topic/188467-fmic/#findComment-3398401
Correct siddr20, the Trust ones don't need the blades cut nor do the GReddy's but I beleive they are the exact same just rebadged
So your sure that the Trust/GReddy ones don't need to be cut? even for the NEO RB25?
https://www.sau.com.au/forums/topic/188467-fmic/#findComment-3399303
series 1 r33 here and i installed a JJR intercooler kit...didnt have to trim the fan blade and it doesn hit either...even underload
i believe the s2 is the same deal...although some people say that it hit, some say it didnt. If it doesnt have clearance you can always gently notch in a small dint in the underneath of the piping with a peice of wood to make it clear....someone i know did that and it clears now and no need for fan triming :rolleyes:
https://www.sau.com.au/forums/topic/188467-fmic/#findComment-3399618
Just a get a Blitz LM cooler or ARC, with return piping so no need to cut holes or fan. And it should run more efficient since it doesnt sit above the rocker cover or radiator.
ok, noob question.. Return piping?? I've heard ARC are sweet intercoolers, but what is return piping???
https://www.sau.com.au/forums/topic/188467-fmic/#findComment-3399880
Yep, BLiTZ M is good, thats what I have on my R32, well whats going ON my R32.
Attached a picture for you noob :thumbsup:
Thats the cooler that will be going on my R32, you can see how the piping comes to the one side.
Return flow is when the piping runs to one side of the car, and up into the engine bay the same way the stock I/C piping does.
Abu
https://www.sau.com.au/forums/topic/188467-fmic/#findComment-3399965
I've got the Blitz LM kit on my R34.
I'm at work atm so this is the only pic I could find.
Sweet setup bro, what ius that thing just to the left (picture, not car left), of the intercooler??? Oil Cooler???
@ Abu.
I see mate, thanks!
https://www.sau.com.au/forums/topic/188467-fmic/#findComment-3401448
I'm gunna jump on the wagon too..
I also have R33 GTST S2, 40th anniverssary (though pretty sure it's the same)
Was thinking of getting greddy 300x600x76.
Should I expect any increase in lag with this cooler?
If so is it worth changing to the R34 GTT one?
I dont plan on going crazy with mods for more power in the near future, maybe just a pod filter and I already have 3" exhaust.
Also any other basic tips would be appreciated..
Thanks in advance!
https://www.sau.com.au/forums/topic/188467-fmic/#findComment-3401503
i've certainly noticed more lag after installing my fmic - eventually i'd like to go to a front facing plenum to reduce the pipe-maze a bit and see if it helps. also am going to wrap my return pipe in front of the radiator in heat-proof shielding to see how that goes cos that pipe gets stupid hot!
oh also have a jjr fmic and just bent the bracket that the return pipe uses to attach to the engine so it clears the blades - looks a little ghetto but looks aren't my concern.
Edited by made_guy
https://www.sau.com.au/forums/topic/188467-fmic/#findComment-3401566
Thanks guys..
I am also taking into consideration that I live in Alice Springs and it gets DAMN hot and dry. I don't know how this will affect my car...any ideas? I don't think it will be too much of a problem, maybe just a little loss of power..
https://www.sau.com.au/forums/topic/188467-fmic/#findComment-3402209
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
