whats this cheater bar im guessing not Jerry Springer styles
cheater bar is a hollow metal bar with extra length used as a longer lever. truckies used them a lot, but they're highly illegal in a lot of industries (as if ya dont know what ya doing its a danger)
Yeah looks like the way to go but pity we can't lock the diff to stop the hub from spinning as there's no gearbox in the car :)
try locking the brakes on, or drop the tailshaft off and find a way to lock the front face of the diff centre
https://www.sau.com.au/forums/topic/188470-hubs-bolts/#findComment-3398355
You should be able to find a point of rotation where the hub doesn't move much (without the need to lock it) - you only have to break it - then it will be easy peasy. I would buy some 'penetrene' (which is a spray not dissimilar to WD40) that will get into the thread and make it much easier to undo. I have a bottle here if you want to come over and borrow it.
https://www.sau.com.au/forums/topic/188470-hubs-bolts/#findComment-3398627
well Luke got that big nut off very easy but couldn't get any further, and I'm not led to believe we need a press to get it off the axle but we couldn't even get the axle out the car
bit spewn cause i will have to pay wrecker prices for both front and rear hubs :wave:
so if anyone has any bright ideas which are based on fact not how about try this then would be greatly appreciated
https://www.sau.com.au/forums/topic/188470-hubs-bolts/#findComment-3401135
yeah but still no adice on how to get the backing plate or what ever its called with the axel and hub out or do i have to undo all the bold holding the diff in then maybe find sum bolts on the back of this so called backing plate again if thats what its called,
and ive probably run out of time to get these parts :yucky:
https://www.sau.com.au/forums/topic/188470-hubs-bolts/#findComment-3401219
theres a couple silly suggestions in here...
ive changed many of these before, the toolman at pooraka has the socket ($30) u wont find them at autobarn/sprints ect, like a few guys said use the ratchet with a big f*k off hollow bar slide over it for leverage (the longer the better).. note a little hint wrap the bar is some rags as she can let go suddenly and u dont want to scratch your paint, try to use the smallest extension also, as i broke 2 1/2 extensions :yucky:
https://www.sau.com.au/forums/topic/188470-hubs-bolts/#findComment-3401387
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
