sorry for possible thread hijack but.. I also Have R34 GTT with Apexi PFC (Standard not PRO - so no spark cut or 2 stage launch control)
I am interested in getting a *Bee-R mostly for 2-stage and the 'hektic sounds' :whistling: but i have some concern over possible engine damage :s
Hektic sounds are great. Throwing a rod is not. What do you want more, a running engine? Or some flames to impress your mates.
I feel that its different in the smallest way. But I feel what peopel are saying is to do is to just have flames and a loud bang bang sound doesn't make sense. It will kill the motor really fast. Anti lag systems depending on what kind will kill the motor faster and I can sit here and list a few parts that will surely fail. But real question at hand, is it worth it.? Ill be doing a anti lag system soon and surly not for the sound. Put it simple I want to win a prize next year and just forking out the cash would be easy to do, but the challenge is using a car to win the prize. Its more than just a tangible prize though.
In short I do agree that these devices speed up the destruction of the vehicle's engine. I hope its worth it.
Oh I remember the old days of piggy backs before it took me years to learn just to get a new ecu that can do it. Lol. I never thought it would be this beneficial. All the other stuff was just a bonus.
Edited by MJTru
I don't know if power fc uses ignition cut.
My response was in regards to the post above mine where it was said, how one can be safe and the other not.
Ignition cut is hektik and makes more than your exhaust go bang.
Fuel cut generally speaking better for the motor.
Power FC uses fuel cut, Power FC PRO uses ignition cut.
The way i understand fuel cut can cause lean condition but ignition cut can damage turbo and exhaust system.
Is cutting both a better idea for rev limiter? (Obviously no good for launch control) or would it be a very harsh power cut?
I don't understand how this can be the case.. petrol has a very narrow window of air/fuel mix where it will ignite. if you are leaner than say 17:1 then it will not fire. fuel cut cuts ALL fuel. The only way you could get fuel into the combustion chamber is if it were left over from the previous combustion event. pretty unlikely to be enough fuel to make a flammable mix. when an ECU cuts fuel to a cylinder it needs to decide before opening the injector, it would be pretty f**king stupid for an ecu manufacturer to put out an ECU that decided to stop fuel delivery mid-injection.
also, ignition cut and antilag are different things.
I like how people try to promote the Bee-r ignition cut system by saying its better for the engine to run overly rich than lean. As if somehow running lean for a fraction of a split second during fuel cut is worse than the massive shockwave ignition cut causes. Its practically a nuke version of detonation.
Edited by Touring
I never really set out to agree or disagree with you :)
But I think the bottom like here is the type of people who want the bee-r system only want it for the mad props effect. They don't really care about their car and are only in it to show off popping fire in front of girls, if the car dies then it dies and they move on to the next car they will abuse.
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
