hi guys, i have a R33 Series 1 GTS-T for wrecking.
Wrecking due to cannot get compliance. Rust in many areas., mostly body.
ALL PRICE HAS BEEN DROPPED!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Tosaki Front mount Intercooler no piping $200
Blistein Suspenision $500
4inch ,massive Unknow jap brand exhuast dump pipe back straight through no cat flared tip loud as $300
rear diff includes cradle$350
Front disk $140 pair
altenator $150
window motors $150 each
cluster $150
Dash main concole $200
Door trims $100 each
radiator bottle $50
washer bottle $50
rear bar $150
rear lights $200 pair
boot lid $200
Passenger Seat $120
rear seat $150
rear window $300
front window $300
side windows $150each
3/4 windows $150 each
Bare doors $200 each
Aircon system $150
sport wheel & boss kit $120
5pieces carpet $80
bonnet $200
front hubs $150 pair
rear hubs $150 pair
side mirrors $80 each
radiator $100
driver foot fuse box $50
engine fuse box $50
fuse box in rear $60
steering arms with rack $150pair
power steering bottle $40
lower control arms $140 pair
starter motor $80
HKS pod filter with adapter $100
rear strut brace $150 each
Rear upper Strut Brace Nismo $150
seat belt and buckle all 5 $100 or $20 each set
R34 GAB Prosso coilover almost new only done 500km's no leaks height & 4damping adjust $850
more parts soon.
just ask for anyother things you need and i'll give you a price thanks for looking
Location (melb doncaster east)
Edited by JYspec
  • Replies 87
Posted Images
wat exhaust system does it have???
and how much for the wheels?
Exhuast: don't know the brand, its cat back very loud flared out tip i think its jap, $450
Rims $850
where in melbourne are ya? mind if i come downa dnpick the things i want? cant seem tot hink of anythign at the top of my head but something will interest me
what brand front strut brace??? be happy to grab it off you for 120. im around the corner in Eltham
cheers
Edited by jake33
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
