interested in the following parts, can i get some photos.
R33 GTR rims with crappy rubbers $850
rear strut brace $150 each
Rear upper Strut Brace Nismo??? $200
you can PM me.
Cheers,
ryan
  • Replies 87
Posted Images
hey would you take $200 for front and rear hubs??
can you pm me your mobile number
i need 5 stud hub because i currently have 4 stud hubs on my r33 GTS series 2? they would fit yeah???
