  • Replies 87
Posted Images
hey i need a rear bumberbar and the reinforcement i need 100%
also need the pertrol tank nozzle housing ie the fuel tank neck insert
i think its only pressed in place
also the rear strut in boot and can u foward me a pic of the HKS pod filter with adapter ???
cheers :glare:
  • 3 weeks later...
more info on suspension plz, adjustable bump n rebound? how much lower than standard? all same firmness? neg?
cheers mate
brett
hey mate im chasing after the driver side power window switch and or the driver side power window motor..thanks
yes i still have., but you need to come and have a look to see if the plug fits.
hey mate, are the blisteins still for sale
1. are you willing to post to sydney? postage price
2. are they height and damper adjustable?
3. are they adjustable to standard height?
4. what model are they?
5. how many k's they done? if unknown, condition - leaks etc??
6. how stiff are they on the street?
7. do they come with spanners etc to fit/adjust?
cheers
cheers
no they are not adjustable.
Guest lilweeksy09
hi guys, i have a R33 Series 1 GTS-T for wrecking.
Wrecking due to cannot get compliance. Rust in many areas., mostly body.
ALL PRICE HAS BEEN DROPPED!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Tosaki Front mount Intercooler no piping $200
Blistein Suspenision $500
4inch ,massive Unknow jap brand exhuast dump pipe back straight through no cat flared tip loud as $300
rear diff includes cradle$350
Front disk $140 pair
altenator $150
window motors $150 each
cluster $150
Dash main concole $200
Door trims $100 each
radiator bottle $50
washer bottle $50
rear bar $150
rear lights $200 pair
boot lid $200
Passenger Seat $120
rear seat $150
rear window $300
front window $300
side windows $150each
3/4 windows $150 each
Bare doors $200 each
Aircon system $150
sport wheel & boss kit $120
5pieces carpet $80
bonnet $200
front hubs $150 pair
rear hubs $150 pair
side mirrors $80 each
radiator $100
driver foot fuse box $50
engine fuse box $50
fuse box in rear $60
steering arms with rack $150pair
power steering bottle $40
lower control arms $140 pair
starter motor $80
HKS pod filter with adapter $100
rear strut brace $150 each
Rear upper Strut Brace Nismo $150
seat belt and buckle all 5 $100 or $20 each set
R34 GAB Prosso coilover almost new only done 500km's no leaks height & 4damping adjust $850
more parts soon.
just ask for anyother things you need and i'll give you a price thanks for looking
Location (melb doncaster east)
hi mate
i was just wondering do u still have that boss kit ?
if so how much for just that ?
also do u mail it out or is it pick up only ?
thanx mate
lil weeksy
