hey guys the other day i filled her up and put some injector cleaner in the day after some strange things started to happen, after goin on a long drive 30km she starts to run like shit like theres no power and the whole car shakes and sounds more like a wrx, after leavin the car turned off for an hour start her back up and she runs fine again til another 30k's headin home, happened again two days later went to work stated doing it but when i was sitting at a set of light she went back to normal with all the power she had,
i ask my mec he said run her til she empty change fuel filter and fill with a fresh batch of fuel so there none of the injector shit left in the tank he said the stuff is bad and he is from x-speed in perth.
just wondering what you guys think
i think the injetor cleaner has gotten the fuel dirty with shit from in the tank cause i pulled the fuel filter off and black shit came out of, i mean BLACK shit
the mods i have done are
3" turbo back
front mount
pod
apexi neo and tuned
cheers guy? :rolleyes:
https://www.sau.com.au/forums/topic/188544-r32-gtst-runing-strange/
When was the last time you changed the filter? I've never had a problem with running injector cleaner.
I'd put money on the ignitor module - they have a habit of misbehaving when the get old and too hot.
i just changed the filter the other day to a new one, ive never had this happen, all through summer last year she ran fine just started the day after putting cleaner in the tank, only does it after 30 mins your so on a long drive to work freeway speeds
I had very similar symptoms, car would drive fine for a while then out of nowhere just start shaking and coughing and spluttering. Turned out to be my AFM so maybe look into that. You could take it off and clean the element with contact cleaner or something similar.
i had a look in the forum for other post with problems like mine so i tryed the cold down the module one when she started doing it sprayed it with freeze spray started her up she was running fine, i think its on the way out because the module is startin to make a very loud electric tickin nosie to that wasnt there before can hear it over the injectors pulseing
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
    • The log you did with ECU voltage, can you log the other things too like rpm and oil pressure? Need all that info together to compare easily
