  • Replies 40
have you tried cranking over crank with a ratchet just to make sure it hasnt seized, if it hasn't as long as when you changed all your electrics over you put your series 1 coil packs and igniter over then you should use the series 1 ecu and it should work. only thing left is a loose connection or blown fuse or realy, easist to pull out all the fuses check if they are ok, i dun remember how to check relays mabye try swaping the mayor ones around if there are any and smell then see if they smell burnt out, then if that fails start checking ALL of your connections you have made make sure everything is hooked up and hooked up correctly and properly
Dont dry cell batteries need a charger with a lot more oomph than normal batteries?
What sort of battery do you have and what charger are you using?
I had my dry cell on charge with a small charger for quite a few days...lol it didnt work at all :)
Maybe try a new battery (not a new dry cell they can be $$$$) at least it will rule it out.
well i brought a new battery its worked well sort of
it primes everything up all sweet n shit all lights work
but its wont fire the starter motor
can i have put the wires on the wrong terminals on the starter motor
does anyone have pic of whet side they go on ??
Noone on here will be able to tell you with certainty what your problem is. Grab your multimeter and start by checking the voltage across the starter motor when trying to start and if that's no good check for continuity (resistance) between the ecu (pin 43 i believe, but check this) and starter, check the fuse etc. There isn't much really to the circuit apart from the ignition barrell. If the ECU isn't sending the correct signal (eg. series 1 vs 2) then you have basically no chance.
Is the ECU spitting out any error codes? Is there power to anything else? (water temp sensor, CAS, AFM, coils, fuel pump as random examples)
Edited by govich
i know that but im elimanating anythin possiable
error codes ?? how do i find this out
and where is pin 43 on the ecu
my hole wiring loom in s1 any wires or elec componants are s1 all i dont was use the head and block
when you say you dont have any spark or inj do you mean the starter try's to crank it but it doesnt turn over just going tick tick tick?? are both the injectors and spark not working how have you tested for both? is the fuel pump priming?
Try swaping with a known good series 1 ecu, make sure the ignitor pack is plugged in properly, double check you havent missed pluggin in any of the connections. are the ignigtor packs known to be good?? stupid question but did you transfer over your spark plugs sometimes people forget the obvious things.
i have plugged everythihng in
the pump is priming
its turning over
the ignightor pack is pluged in
spark plugs are in
i tested them all
spark plugs not sparking
inj not pulsing
all tested
  • 3 months later...
have ya found out what the problem is yet with your car
i have a similar problem at the moment. The car was running previously but then now wont start. The engine is turning over but just wont start.
different power fc's have already been tried. Spark plugs, coilpacks, different CAS will be looked at monday.
    • Pre-empting heat management  1. The Kraken manifold will be ceramic coated 2. Just purchased some peel and stick heat shielding stuff from car builders, I'll cover some of the firewall behind the dump and a little on the cam cover, this will be done prior to installation as I have ample room to get where I need to now before that realestate has more bits in the way, I'm also planning to modify the OEM heat shield to go back on, but that won't happen until after installation so I know where to hack it up, I'll also cover it with some some peel and stick to neaten it up after the hacking 3. As the dump is stainless with a flex joint coating isn't really a option, and wrapping isn't recommended for a stainless dump, so once it is installed I'll grab some shielding from car builders to cover the dump, as it has some stand off, it "shouldn't" cause any issues and it "should" just keep the radiant heat away from " melty engine bay stuff" Not for heat management, but I've grabbed some more black crinkle coat to paint all the shiny intake pipes, I'll pick the pipe work up prior to installation and use the paint booth and big oven at work to cure them, I'll then wrap them with some bubble wrap so they stay nice during installation
    • We're back on, gang - Our yearly pilgrimage south to our favourite cafe for an awesome brekkie! Yes, that's right... we're heading down to Austi Beach Cafe for a breakfast run through the Royal National Park! Before you drool over your phones/keyboards, here are the details: Date: Sunday 23rd February Meet Location: Loftus Oval Carpark, Royal National Park, Sutherland Meet Time: Meet at 7:00am for a 7:30am departure Destination: Austi Beach Cafe, 104 Lawrence Hargrave Drive, Austinmer Map: http://tinyurl.com/saunsw-austicruise  RSVP: If you are planning to sit and have breakfast with us, please let us know, either by posting in the event, or by messaging us direct so we can confirm numbers with the venue. Itinerary: We will meet at Loftus Oval Carpark which has plenty of room and is low car friendly. This is a quick turn into the Royal National Park and some nice roads and scenery. After Stanwell Tops we will turn off and head onto the awesome Sea Cliff Bridge. Following this it is a short trip to Austi Beach Cafe. There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • YO- have been searching and searching for an a31 chassis plug pinout, or someone who knows which wire is for tach.  ceffy was flooded past dash during a hurricane.  having an electrical gremlin appear. tach is wonky reading consistent with a short, and on occasion the right side of my speedo lighting will flicker just for a second then go back to normal.  if no pinout available does anyone know if the tach harness opens or branches anywhere behind the dash? im suspecting a possible root behind the radio as there are more shorts in that area on the accessory loop.
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
