Thanks a lot for your responses :happy:
I have another question now.... When the time comes I will buy another R33, but the other day I was brousing the J-SPEC Imports website and came across some really nice cheapish r32 GTR's with around 60,000kms. Do you guys have any reasons why you would choose one over the other given the chance?? 32 is older but it's a GTR and I really like 33's so not sure.....
Cheers
haha i still have no idea what that sticker is, half the people i ask say its when you should and the other half say its when its done.
As for 32 gtr or 33 i'd say 33 just for the fact that despite the sheer sex of a 32 gtr, they are old cars. Get a 33 GTR, best of both worlds and then some :happy:
my sticker has the kms when the belt was changed written on it, not when it is going to need to be changed
the silver sticker is like a proper printed factory sticker with a line of Jap then underneath it has 100,000kms and more Jap...
are you saying yours has like 96,842kms or something like that instead? Or do you mean there's a different handwritten sticker there?
the sticker is simply there so to be written on when the car has had it's timing belt changed/100,000km service. I would not be buying a car that has no sticker on there as why would you remove it unless it has done >100,000km's/had it's timing belt already replaced...
Steve,
If you get a bad example of an R32 GTR it will cost you large amounts of money for repairs... GTR's are always going to be more expensive to modify, repair and maintain than GTST's as they have more to go wrong eg: 2 turbo's, 2 diffs, 4 axles, transfer case... etc.
GTST's arent as good as a race / drag car though for obvious reasons, also they are a lot more common than GTR's.
Bottom line... GTR is a better all round car, but its easy to get in way over your head money wise if you get a bad one.
GTST is cheaper, more common but still a great car for the price you pay.
Edited by Bullet32
Of all the R32's I see getting around I reckon it's 90% GT-R versus 10% everything else R32.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
