Hi Guys
At the moment I'm looking at upgrading my cat because the car is a bit loud. Drones like a bitch between 80kmph and 100kmph.
Currently Producing 300rwkw and looking at the 3.0l bottom end in the near future.
Anyway, the current exhaust is 3inch off the Turbine, and another 1.5 - 2inch from the waste gate plumbing back in just before the lower bend in the front pipe. The Cat that is there has 3 inch flanges and is one of those "extreme flow through non restrictive" ones.
Anyway, I've searched and seen a few threads about a few Different cats:
Catco
Metalcat
SMB
Xforce
Does anyone have any recomendations for me? I want to retain power and get rid of this drone, and quiet the exhaust a little.
Thanks guys
Edited by The Mafia
i think you forgot a few things, what is it from cat back? as well as what it made of mild, stainless, titanium? these might help as well. the Cat itself doesnt really hinder on noise control as far as i know, its other factors usually from the cat back, IE: Resonators, inner mufflers and the likes, as well as mild steel does drone. aswell as what size is it from the Cat back.
Ive got same issues, but running the highflow metalcat heaps of drone, but running 3.5 to resonator to then 4" through from there to a cannon, its expected with that esp when in mild steel. Gotta love the drone... inner mufflers may help but may hinder on overall power through restriction tho changing from mild steel to stainless or titanium cat back usually will help as well.
Correct me if im wrong
Cheers
A
Changing from twin high flow cats to twin metalcats on our supercharged xr8 made a huge difference in noise (alot louder) so if noise restriction is what you are after id stay away from them, but 300kw is a fair bit for a street car so im guessing you do track work? maybe a straight through pipe as thats what i have on my 34 and it doesnt drone and isnt too loud...
Hi Mafia , one thing I've never gotten around to proving is the worth of putting "soft spots" along an exhaust system to beat that low frequency vibration or drone .
The story I get is that everything has a set or natrural frequency point where it will ring like a bloody bell and transmit vibration into everything around it . It seems to me that large exhaust systemys are quite rigid and capable of acting like a great long engine steady - transmitting lots of vibration to our speaker box like cabin area .
David Vizard used to say that exhaust systems should be hung not mounted to isolate unwanted noise .
I tend to think that if soft spots like those stainless mesh covered concertina things are placed along the exhaust in a few places the tailpipe loses much of its rigidity and can have its vibratioin isolated by well thought out flexible hanging mounts . I remember on occasions being in Goulburn where they have an Olden dealership and Commodes backed up on ramps , they seem to have quite a few soft points down the back and I doubt its to do with stopping the pipes cracking when the engine moves about .
By any chance would the drone occur at low revs in high gears and mysteriously correspond to 60/80/100 km/h ?
Any how I'm interested in what other peoples thoughts are , cheers A .
Could we assosiate this drone to resonance frequency? I could well associate mafia's problem to similar background to mine, as i have got the "Drone" syndrome with mine. mainly around the 80-85 it would start, and reach around full drone around 100-110 around that area, where it is quite loud. this would be assosiated with 5th gear, so around that rev range it does it, 4th gear would be similar to around the 60 mark, but no where near as loud as 5th at the above speeds.
On the theory of the flexible hanging mounts. Im not too sure if they would be greatly assisting the problem no matter how many you put in or have, as the metal itself would still have its natural RF properties, and would still occur. Changing the characteristics of the metal will help, Stainless vs Mild, Stainless having that tinny sound while Mild having the drone. The only way I can see to minimize the drone, is to either change restriction value of the system, ie: mufflers, resonators etc. and change to a better steel compound mild to stainless/titanium.
Cheeers
hey guys sorry I haven't posted yet.
Its a Stainles 3inch+1.5inchWG system to the cat, then from there 3.5inch mild steel to a 4inch cannon and a 5inch tip..haha. Its very big.
I was talking to cubes and he said the cat will need a pipe put through it, as this one is just "super high flowed" lol.
    • looking forward to your t56 swap man its a game changer if it works!
    • So, when are you trying the new GR86 or BRZ?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
