Just wondering what would be a good intercooler and good size core for a GTR. brands im currently looking at are PWR, ARC, Blitz, Trust and Nismo(if i can find a place who sells them, and a price)
i know it will be a case of "what do you want to do with the car" forget that phrase, doesnt mean anything to me as i will still do what i want in the end!!!! just want peoples opinions on the brand, how well they work and whats a good sized core(thinkness wise)
thanks. James
Edited by Turbz_13
https://www.sau.com.au/forums/topic/188618-intercooler-selection/
i know it will be a case of "what do you want to do with the car" forget that phrase, doesnt mean crap to me. just want peoples opinions on the brand, how well they work and whats a good sized core(thinkness wise)
thanks. James
Well that phrase should mean everything to you. Someone could suggest you get a massive thick trust drag item that will create lag when you're after response, or vise versa someone could suggest a smaller core when you're after 30 million rwkw's and it'll choke top end power. All of those intercoolers work briliantly for there intended purposes. As for you intended purpose, no one can tell you how well they work for that if no one knows...
I would say the stock gtr cooler is good for up to 350wkw for street applications. The stocky is around 60-ish mm if im not mistaken.
For anything over that, most people go for something like 600x300x100.
Edited by Yawn
Whats the benefits in going over 75mm, I live in darwin its damn hot all the time.
Is a quality 100mm core going to restrict flow to the radiator much over a 75mm.
Is there going to be a major change in response. Have a crappy bent up fins 100mm at the moment so have no idea what stock was like
And looking for an upgrade running 2530's poncams powerfc usual mods and more for track than drag but keen to do a little of both
and the odd motorkhana just the usual stuff
Sorry if this is a bit of a hijack but seems I am in a similar situation
The standard GTR intercooler isn't shabby at all, pretty good core design and pretty much perfect end tanks.
I invested in a custom ARE built intercooler after changing to group a turbos and it certainly was significantly better than the stock unit with the bigger turbos. www.are.com.au
If you throw away the idea that the cars purpose has anything to do with intercooler selection then you lower your odds of getting the best. ;)
as far as im aware, not sure if the 33 and 32 gtr cooler is the same but the 34gtr cooler is good for 500HP... so if the older style gtr coolers are the same it shud see u to 350rwkw easy. but seeing as its an old car now i wud prob go for a good 75mm cooler.
Here is the deal. for what you want go for a core thickness between 70mm and 100mm. I have seen and sampled lots of coolers and the ones that stand above the rest are ARC and nismo. both can be had around $1500 or so. Me, I would go the ARC, but the nism one is top notch too. for you I would go 70mm for 350rwkw 100mm is overkill and will just starve your radiator of air more than anyting else.
I agree Beer Baron and Ronin_09, as im using a 70mm ARC unit myself, with similar power output to what you want.
You can get the Nismo gear from Nengun or greenline etc., or a few traders from this forum can import one for you too.
my 32 GTR also has GRP A turbos and with the usual mods STD intercooler saw 320 ATKW with 20 PSI intake temps were fairly high and after a few runs was loosing power, and detonation was a real issue, there were a few options, cooler sprays or upgrading cooler.
I was going to go for a TRUST drag cooler or ARE cooler, the prices quoted did not fit my budget ($ 1800)!!
decided to get one of those cheap EBAY coolers ($380) 120MM thick and never lookled back after fitting up it made same power on 16PSI with minimal preassure drop. with 22 PSI made 460 RWHP and intake temps were no probs even after re-tuning on a summers day.
by running twin compressors it pushed the air through quite well (compared to big single) and only changed boost range by 400 revs. NO LAGG!!!!!!!!
water temps didnt move that much.
Cheers
Be aware that the thicker core you go the more you need to cut from your front bar to fit it.
a 70mm core is probably best for fitment and would suit what you want. ARC, Trust and HKS will do the job.
Nismo stuff will not be any better than ARC but about 30% more on the price tag. Both are direct fit items if you buy the correct one.
120mm thick is overkill for that application and you would see more response from your setup with a more reasonably sized core.
not all large upgrades require cutting the bar. mine, only a slight mod of bonnet latch and removal of one of the two horns.
Yep i agree a bit of overkill but as stated only cost $380,
and dont forget that a lot of the "better" branded items are now made in china, possibly even the same factory????
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
