i was looking at 100mm cores...as i want to throw the twin set up and got a single set up, and how i was seeing this is at say the same boost level the big single is sure to be pushing more air than the twins. am i correct? so the larger core wont be too bad
ill tell ya now i bought a big fat 120mm cooler and it is the worst thing i ever done as it was nasty very nasty 2 fit,front reo had major surgery...if i was smarter i would have done what you did and asked people...
how does a 100-105mm core fit on the r32 GTR front like? is there much modifying the front bar and reo...not concerned about the reo bar as it needs either to be replaced or to have a bit of time spent on it. thats story for another time...just a stupid mistake someone made that had the car b4 me
i have a 90mm ARE custom job, and the reo and part of the front bar was cut. spoke to ARE and they recommended this tube and fin, will happily keep temps down at track to around 450rwkw. it's a bit overkill but if the motor pops and I build an engine, I won't have to upgrade the cooler again.
mmm...so was there much cut off the front bar for the 90mm core to fit?
what power levels would a 70mm ARC cooler handel?
im not to concerned about cutting up the reo bar. as that has already been done to fit the N1 vents. but would live to avoid cutting too much off the front bar if possible but will if need be
the ARE guys will make you a custom sized core, thats whats really good about them. (www.are.com.au)
yep - they don't make a 90mm tube/fin as standard fitment.
just give them a buzz and have a chat!
on This Page they have a Type E28 610x300x73 core that will do 400kw conservatively...
Ive got a HKS 100mm one on mine and it fits in behind the reo...i thinks its a matter of how well you can manouvre your piping and cooler to get it sitting in the right spot mostly. Even if you had to make some custom brackets like myself...
