Soooo who else is geared up to do absolutely nothing all week once Half Life 2 Ep 2 is released? :wave:
Already preloaded via Steam... should be officially released Thurs lunch (AUS time) I think/thereabouts.
Yay for AUS dollar atm :D
YAY for $5 discount for pre-order :D
YAY for official release time :(
w000t
https://www.sau.com.au/forums/topic/188639-half-life-2-episode-two/
Yeah officially out 4:30 Adelaide time...
Been thrashing TF2 the past couple weeks! Awesome game!
Looking forward to portal too
Had to ditch my old Steam account cos i've been perm banned on Internode... It wasn't my fault i swear......
HAXORING I bet??? :P
HAXORING I bet??? :)
Your steam id has been permanently banned for language, derogatory comments and abuse of players. This is completely unacceptable behaviour and as such has resulted in this ban. The ban will not be removed.
So thats a no :P
Last night i just got totally hooked on Portal!
OMFG where i am now my brain is totally racked! Passed all the training mission and now im... I dunno where i am but ive "escaped"
Will probably Start Ep1 over so i can flow straight into Ep2...
Anyone played any of the Orange Box stuff yet?
haha im banend from internode aswell, apparantly singing on the microphone is bad behaviour
yeh we've been playing HL2E2.. was too easy to start with and seemed a bit disappointing because of that... but now it's hard and I've actually died a couple of times! :) The flashlight seems to last longer now.. but it's still such a small scope of vision that I'm going freakin blind... so dark all the time! Doesn't load as often which is good..
I don't like how when you turn around for half a sec you can't hear what Alyx etc is saying.
Apart from that it's all good so far.
But anyway I won't say anything else so I don't ruin it for you guys :O
Baconer - haha I guess it depends on your singing skills... eardrum abuse deserves a ban :D
Yeah they can be Nazi's over there at times... But at the end of the day i recon Node has the best servers in the game!
BTW anything and i mean ANYTHING "non-game related" over the mic is bannable lol
So i tend to abuse/curse/make sounds in moderation now.
haha Portal was hilarious, how good is the song (link) at the end and some of the quotes
*female robot voice*
"Remember when we pretended we were going to kill you and you were like "No way" and we were like "Just kidding!"? Wasn't that great?"
Good game aswell, good to see a nice original game concept, hope they are linking this into HL: Episode 3.
Edited by Baconer
    • Gosh these Rb pulleys/alternator or whatever is causing the problem is absolute rubbish lol. Haven't even done that many km on it.
    • Yeah man, will only progress further hopefully. The bonnet is coming off to get sprayed very soon
    • Once the belt slips it can very easily cause a cascade that encourages more belt slip. Check the pulleys carefully and see if the grooves have cupped. If it has it's time to replace the pulleys. If the rubber has glazed you also need to replace it. Shouldn't be shiny. From the factory there's a lot of exposed fibers(?) on a v-belt that will go away as it's broken in but some should still remain visible without sticking out significantly like a new belt. I went through this on my dad's Camry recently. It would keep slipping even after setting the tension higher, only solution was a new belt.
    • Belt polished and/or pulley(s) glazed. Rub pulleys with sandpaper, replace belt.
    • I've also got a quick jack. I would never get under my car again without using it.  While it might be quicker to use a jack and stands, it is such a quality of life improvement that I wouldn't have it any other way now.  How much slower the quick jack is to setup will be based on your circumstances. Can you leave the jack rails on each side of the garage? Can you leave the hydraulic lines attached? etc.  If you can drive the car into the garage and simply push the jacking rail thingos under the car into place, it is super quick to setup and use. But if you have to pull the pump unit out of storage, attach the hydraulic lines, wheel out the lifting rail thingos.... yeah takes a bit of time. Having said that, I would still prefer that to using a jack and stands lol.
