Who had the wheels off last? They could have just forgotten to tighten one of the nuts and its come off?
Nah... its much more fun to hate those thieving bastards :)
it wasnt loose, i checked them after i bought the car, so they were all tight, plus like i said i didnt drive the car for 3 days and it went missing before i drove it again.... anyways im over it so pissed off but need to just replace it
  • Replies 60
that blows. I cant see why someone or even how they would steal one wheel nut?! I mean they'd need to be carying a bar and 19mm socket and then why stop at one? whay not take em all, or take 4 off each wheel? I reckon it just fell off.
I will try and see if I can get one nut for you.
hmm wen are u getting the others? and are ur old ones scratched up heaps?
I think they should be only a week away???
Dont think they are scratched up??? Im going to the car on Saturday.... Il have a look.. but if you need one straight away il just grab one off mine as its not going anywhere for a couple of weeks anyhow!
Yours are the short ones yeah???
thansk rich.... let me know if u find :)
yeh i was thinking the same, but like i have said it wasnt driven.
i mean it got washed on saturday, and all nuts were there, then monday i noticed it, and didnt drive the car since the saturday
hmm not sure if they are short..
never had them before so i dont know the diff, but they look like they are longer then normal short stubby nuts..
They look like the short ones in the photo.... they are about ummm few cms long I guess??? The longer ones actually stick out from the rims a good few cms once they are tightened....
Il grab one off the car when head there unless your around Penrith at all then you could possibly stop at the workshop and take on off yourself a bit earlier??
I reckon there could be two reasons you're missing a nut
- Someone just wanted to be a dick and stole 1 nut
- Someone was trying to steal your wheels but was interrupted and left quickly.
yeh i was thinking those, but also one more:
-some loser was missing one and decided he'd take one of mine... (doubt it tho)
Kids these days....
When I was a kid I used to see a nice car and stop and stare - not throw eggs at it...
We need to put up a Youtube video of the public castration of a little egg throwing, rays wheel nut stealing bastard! That'll teach em! :)
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
