4 Doorz Posted June 22, 2003 Share Posted June 22, 2003 My poor car II Saturday morning I work up and started my car and it started revving at 1600 rpm....I thought nothing of it, thinking it was just cold start, but after driving for 30 minutes it was still revving at 1200 rpm. today we tried to reset the Throttle Position Sensor, but it was still revving at 1050 rpm... Does anyone know how to make it go back or has anyone had this problem before!? Heeeeeeeelp!! Link to comment https://www.sau.com.au/forums/topic/18866-reving-like-a-rotary/ Share on other sites More sharing options...
MotoX Posted June 23, 2003 Share Posted June 23, 2003 try reseting the ecu. Link to comment https://www.sau.com.au/forums/topic/18866-reving-like-a-rotary/#findComment-396267 Share on other sites More sharing options...
MotoX Posted June 23, 2003 Share Posted June 23, 2003 or else theres a little screw that makes your idel go up and down on your throttle body, i think its your TPS screw, im not too sure, i adjusted mine, it idles at 800 now. (when warm) Link to comment https://www.sau.com.au/forums/topic/18866-reving-like-a-rotary/#findComment-396272 Share on other sites More sharing options...
slip Posted June 23, 2003 Share Posted June 23, 2003 check to see that your throttle cable is fully retracting, just play with the throttle body under the bonnet. Link to comment https://www.sau.com.au/forums/topic/18866-reving-like-a-rotary/#findComment-397891 Share on other sites More sharing options...
greygirl1976 Posted June 23, 2003 Share Posted June 23, 2003 Originally posted by 4 Doorz My poor car II Saturday morning I work up and started my car and it started revving at 1600 rpm....I thought nothing of it, thinking it was just cold start, but after driving for 30 minutes it was still revving at 1200 rpm. today we tried to reset the Throttle Position Sensor, but it was still revving at 1050 rpm... Does anyone know how to make it go back or has anyone had this problem before!? Heeeeeeeelp!! i had the same problem do what motox says disconect the batery power i left it off over the weekend coz i went away reconnected it havent had the problem since if u do it u only have to disconnect the power for 5-10minsthat should fix it Link to comment https://www.sau.com.au/forums/topic/18866-reving-like-a-rotary/#findComment-398374 Share on other sites More sharing options...
MotoX Posted June 24, 2003 Share Posted June 24, 2003 greygirl1976 the easiest way to reset it, is to. undo the battery terminals. put you foot on the brake pedal for a good 3min's and leave your headlights on. Link to comment https://www.sau.com.au/forums/topic/18866-reving-like-a-rotary/#findComment-398627 Share on other sites More sharing options...
MotoX Posted June 24, 2003 Share Posted June 24, 2003 its jsut it has to drain the power out of the ecu so it is blank. then when you start it again, it will run funny for 2secconds rev low then rev high. you never know, you might get more power out of your car. i certinally did. Link to comment https://www.sau.com.au/forums/topic/18866-reving-like-a-rotary/#findComment-398640 Share on other sites More sharing options...
4 Doorz Posted June 24, 2003 Author Share Posted June 24, 2003 I got home from an exam the other day, and for some strange reason, the car just dropped back to 700 rpm! No notice. I was strange since I have got used to it revving at like 1200 rpm...but now it is all normal :confused: Thanks for your help though guys Link to comment https://www.sau.com.au/forums/topic/18866-reving-like-a-rotary/#findComment-399299 Share on other sites More sharing options...
slip Posted June 24, 2003 Share Posted June 24, 2003 heh, my car starts to idle rough, then gets to a stalling stage, then is suddenly fine, its done it a few times. skyline = shitbox. Link to comment https://www.sau.com.au/forums/topic/18866-reving-like-a-rotary/#findComment-399643 Share on other sites More sharing options...
Parag0n Posted June 24, 2003 Share Posted June 24, 2003 sif they are Link to comment https://www.sau.com.au/forums/topic/18866-reving-like-a-rotary/#findComment-399775 Share on other sites More sharing options...
