  • Replies 72
I got that added to the order added into ours for you Richard.
Extra 4 bucks shipping or something.
My credit card shows 2 orders
In AUD
83.60
182.55
266.15
266.15 / 3 = 88.70AUD each...
In AUD
83.60
182.55
266.15
you are a champ :spank:
send me a pm with your details and I'll send you some cash now. cheers.
I think you guys are forgetting that the more pads you put in a package, the higher the freight charge is going to be....
Titanium is pretty heavy remember :P
:spank:
Titanium is actually pretty light. Which is one of the reasons why it is used.
Check the Shadow Can Am car. Number 22 unsurprisingly enough.
http://www.vintagerpm.com/shadow_history.htm
http://www.motorbooks.com/Store/ProductDetails_39357.ncm
I think bass junky was being sarcastic... seeing as how he's an engineeer I'm fairly certain he knows the relative weight of titanium! and actually I didn't think titanium was light as such, just that because of it's strength it can be used in thinner sheets for a given application than you could with alluminium etc. so you get the weight saving because you are using less of it than you would of other materials.
I used to get sarcasm, but since this whole interweb thing happened I can't pick it any more. Much like Ford Prefect. :spank:
Broadly steel density is 7860 kg/m3.
Titanium is about 4400kg/m3.
As for strength well it depends on what type of alloy, but not dissimilar in its range to steel.
Much of its gain/utility is at high temperatures. Aluminium, for example, is complete rubbish at high temps.
Lastly, wtf is it with engineers & Skylines. Am I just conforming to a stereotype being one & having the other, or is there something more too it than that?
You lot should harden up & get some castlated pistons.
Edited by djr81
can't wait to get these. then I'll fit some hiclones into my brake ducts too just to be sure. maybe a peter brock fuel polariser to up the power now that my brakes will be so kick ass.
Hey Baron, seeing as you are such an expert. If I fit a magnetic fuel expander to my car will it upset the uptake of Orgone energy through the polariser?
you need a brotec MFE-con. it controls the magnetic fuel expander maps to keep it all in harmony with your cars natural feng shui.
and yes I'm a sucker for Ti. I even have a Top Secret Titanium ash tray. :spank:
baron you are a stroker...
lol
can't believe you clowns ordered Ti shims.
do me a favour, when they come, get a gas soldering iron (or one of those little gas brazing jobbies), give one side of the shim a nice going over (say, around 600 degrees), then tell me how hot the other side is
lol
how about I rest one on your nipple whilst you're sleeping then put the gas torch on your knee cap. then try it again without the ti shim and see if there is any appreciable difference? :) or if you will just admit that you are jealous of them we can team up and do it to brisby instead. your call.
What about HPC coating(not sure if thats right like they do with exhaust manfolds you get what I mean :P) the shims? Wouldn't that give you a better thermal resistance than just bare metal on metal...whatever that metal might be?
i saw that andrew, though still skeptical - it's their site pic
would like to be proved wrong though, if it works i'll get on board!
No, the magic beans are ours, you can go spend 5k on a bigger brake kit :)
Even though the theory works, i still don't believe it to much, but we'll see hey.
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
