Ahh, just found out a mate from school is going to do it.
Just gotta pay sum1 to do the wiring.
Anyone with much info on it?
Is it
Straight swap? mounts line up? gearbox line up?
Were can i source a cheap halfcut?.
I Dont need Ecu as i have a 33 microtech.
Whats needed to be done for a mod plate?...
Thanks.
man do it yourself, i am.
doesnt look to hard i will find out as i go.
i will gettin help from the lovely people from SAU if i need it though.
prob be able to get a from cut of a r33 for like 3500 if that, that gives you everything you need.
mechanics if you make it easy for you will prob do it for 2-3 K drive in drive out. with no other modifications.
Is it
Thanks.
yes and no...it is a straight swap but it isnt....
you need to change the gearbox mount and the tail shaft..
use whatever computer you want, just tune it.
dont mod plate it....:O you shouldnt need to.
the r32 came out with a 2.5 ltr....or just dont advertise it as a 2.5 ltr you should be fine....
but i would mod plate it cause it is illegal not to....savvy
gearbox mount needs to be modified...weld abit of angle along the back of it to pick up the last two bolt holes.
do it yourself and you might learn something about your car.
Edited by r33_racer
You can keep the Rb20 box (i have) but may not last you long... if you are going to use the rb25 box you will need to get a shortened tailshaft made up for around $700.. and you can use the existing rb20 harness if you make a few minor changes... it's all easy if you have a soldering iron hehehe
do it yourself ..... i have been quoted over $6000 for a conversion i did under $2000 :thumbsup:
dont mod plate it....:) you shouldnt need to.
it easy as to get it mod plated cause like you say the 25de is an option in r32s I think it cost me $160 to get mine plated
people could save them selves the trouble and but mine???!
3500 for a R33 GTST cut.. damn they have dropped...
Do TTR still do them? lol from memory the were around 5k
no offence but i knw of alot of ex employees from TTR.. and i knw of alot of stories.. as in moding the CA loom to fit RB20s. pm me if u want details.. i jsut dont like the company
do it yourself ..... i have been quoted over $6000 for a conversion i did under $2000 :)
yeh well help ya. throw up a BBQ and ill poke at ur engine.. but u make me work too much ill expect moolah haha
yeah you can keep the box, i was gonna but then i thought...when it breaks....so i got a 25 one.
i heard that you can just change the yoke on the end???!?!?! or use a r33 front tailshaft piece. i could be wrong...i will crosse that hurdle when i get to it.
i didnt know you could use the 20 harness...thats cool as.
sif man pay you, we'll whip you till your finished the conversion.
Can help with the wiring. I have done a few now. Excellent conversion, I even did one for my fathers R32 at the start of this year. He loves it!
I have personally done 2 now and have done them over a weekend with a hand from my bro-in-laws.
Cheers
Is it
Thanks.
It's easy if you have the tools and know what you are doing, it takes more than anyone is going to tell you here on the forum but is not that hard, start using the r32 complete wiring harness only changing the 4th and 6th injectors pins
(rb25 igniton is different.), use r32 ecu, you need to use the r33 yoke (it is the begining of the driveshaft that connects into the tranny), the transmission mounts must to be changed (the r33 tranny seats a little farther than the r32, you'll need to custom your cluster if you are going to use the r33 tranny (r33 reads the speed digitally and r32 use a cable from tranny to the back of your cluster.).
If you don't mind for timing and you want the r33 front end too it's going to take really a lot of work!(I'm doing right now this conversion, r32 with r33 front end and complete front end wiring harness with the rb25 motor....lol it is really been a lot of things to do.)
gl with your swap.
Edited by dk_fabiosantos
if anyone needs a tailshaft made give brendon at petron automotive a call (its on tradelink rd in browns plains) Tell him matt with the rb26 s14 sent you, he will lookafter you.
if your paying $700 for a tailshaft im pretty sure you would be getting ripped off. but it depends what you are after i spose
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
