R33 series 1, M-spec.
It has a top mount Garrett GT3040R turbo, 45mm Turbonetics external Race gate, Apexi pod filter, speed & boost limiter removed,
Fmic, heavy duty clutch & lighten flywheel, Apexi FC, 17's, momo steering wheel, timer, guages, upgraded brake pads with cross drilled rotors... modified intake manifold, adjustable castor bushes, adjustable rear camber bushes, pineapples.. Factory sun roof,
big stickers! 4 inch exhaust from the turbo to the cat, 3 inch cat back. the cannon has a silencer as well. remote lock, immobiliser..
I have onwed the car for 6 years. It has been fun, but my wife is very keen to extend our family, so i am looking to get a wagon for her. Yes, i will be buying another imported turbo'ed car, but sadly the R33 just will not be big enough..
I have spent lots of time sorting the car out, it handles very well, has lots of grip and is a fairly well rounded car. I have not managed to put it down the quater mile or onto a circuit.. but i want to! It has only ever been really driven on the skid pan.. those who have been to a skid day with me will telll you how i treat it..
$16 000
here is the car in action early last year.
Edited by psi
https://www.sau.com.au/forums/topic/188759-r33-gts-t-series-1-m-spec/
if you had those bits in a stagea, i would trade! My family is growing, so I need to sell the toy.
I want a stagea.. that way i can keep all the other bits of been wanting to put onto the 33 and put them into a more family kind a car.. like a stagea!
sorry.
your GTR does look good, and i would have traded u 3 months ago! lol
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
    • That's odd, it works fine here. Try loading it on a different device or browser? It's Jack Phillips JDM, a Skyline wrecker in Victoria. Not the cheapest, but I have found them helpful to find obscure parts in AU. https://jpjdm.com/shop/index.php
    • Yeah. I second all of the above. The only way to see that sort of voltage is if something is generating it as a side effect of being f**ked up. The other thing you could do would be to put a load onto that 30V terminal, something like a brakelamp globe. See if it pulls the voltage away comepletely or if some or all of it stays there while loaded. Will give you something of an idea about how much danger it could cause.
    • I would say, you've got one hell of an underlying issue there. You're saying, coils were fully unplugged, and the fuse to that circuit was unplugged, and you measured 30v? Either something is giving you some WILD EMI, and that's an induced voltage, OR something is managing to backfeed, AND that something has problems. It could be something like the ECU if it takes power from there, and also gets power from another source IF there's an internal issue in the ECU. The way to check would be pull that fuse, unplug the coils, and then probe the ECU pins. However it could be something else doing it. Additionally, if it is something wired in, and that something is pulsing, IE a PWM circuit and it's an inductive load and doesnt have proper flyback protection, that would also do it. A possibility would be if you have something like a PWM fuel pump, it might be giving flyback voltages (dangerous to stuff!). I'd put the circuit back into its "broken" state, confirm the weird voltage is back, and then one by one unplug devices until that voltage disappears. That's a quick way to find an associated device. Otherwise I'd need to look at the wiring diagrams, and then understand any electrical mods done.   But you really should not be seeing the above issue, and really, it's indicating something is failing, and possibly why the fuse blew to begin with.
