  • Replies 107
good stuff glad to hear that Paul and Stace have official RH9
thanks guys
Wow what an eventful evening....
only two passes, still having trouble keeping belts on it. Looks like the alternator has not been installed correctly as it does not appear to be in line with the balancer and water pump pulley.
ok
1st pass only used 20psi and launched to a 60' of 1.5sec, i didn't shift the car too well and when the alternator/water pump belt came off at 3/4 track rolled though at 128 MPH and ran a 10.5. had to get towed back to the pits...not a great start to the night.
We worked in the pits to try a few things to get the pulley's to line up properly and found the bottom of the alternator that attaches to the block not tightened...damn! Bolted it up properly, re-installed the belts and went out to have another run.
2nd pass turned the boost up to 25psi got it to really hook up off the line... 1.44 60'. The 1st to 2nd shift was also pretty neat (for my standard anyway) so when the belt flew off again at the top of 2nd (just past 1/2 track) i thought fu(k it and grabbed 3rd and kept my foot into it. Keeping my eye on the Power FC hand controller water temp reading (i have no water pump) and the other on the finish line went through the traps with the water temp reaching 87deg, but fortunately stopping the clocks at 9.998 secs with a MPH of 137.26. Unfortunately had to be towed back to the pits again, but the 9 was in the bag.
Big thanks to Jim Souvas and Croydon Racing for providing us with a monster engine and an awesome tune. After speaking with Jim this evening he is confident that there is a lot more to come with this set-up.
LTSjayce from Canberra gave me an envelope some time ago that was only to be opened in the event of a 9 sec pass.....
it contained two RH9 stickers...
they were put on in the pits while enjoying the moment with a few of the SAU boys.
nice work i was there but didnt get to see the pass, i drove past in my black 32 gtr as you were putting the beast back on the trailor and you yelled out to me you did the 9, seemed pretty excitied haha.
I also did a pb of 11.16 at 125mph so i was pretty stoked :)
Edited by OFENSV
great work...were you not the same guy i was chatting to in the staging lanes?? thats why i called out to you...and yes...i was pretty stoked.
haha nah it wasnt me but it was good to hear you say you got the 9 becuase i knew you had been chasing it.
So whats the next target a 9 what?
I was getting updates SMS'd in last night and when I got the 9.9 @ 137 message I was cheering out loud and pissing off everyone in a 5 mile radius!
Outstanding effort guys!! Job well done. Elsie's first drag meeting and she sees daddy run a nine!!! She's gonna grow up thinking you know what you're doing Paul!!
Well done guys, gone are the days when you had to absolutaly ring its neck for a 10.3, now it runs close to that on a back off. It is well deserved, all your patience and effort have payed off. up 4 another Queensland trip?
PS. Hope is all well with your new addition also.
thanks guys
ok
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
