My clutch is slipping, not when u engage the clutch but mainly from 2500rpm onwards.
Can anyone recommend a clutch to use and how much approx ?
(Genuine Nissan or other clutches)
Who do u recommend to do the installation?
Has anyone tried to take the gearbox out yourself if u have your car on jack stands ? (or do u need hoist)
Or leave it to the professionals ?
Immigrant performace at Labrador, Gold Coast quoted $930 for clutch and installation.
But Dane said the clutch they use is a heavy duty performace one they have designed themselves which can take 3000 pounds of torque.
Anyone have any experiences with this guy?
Mine Fried on Tuesday...Speak to Gavin Woods. He knows his stuff. Prices seem reasonable for Clutches. He has a couple of different options. Mine will cost me about 900ish installed for a Daikin (his recommendation)...
Call 07 5529 2313
As soon as I come up with the cash I'll be going in to get it fixed...
Michael
i got a heavy duty daikin put into my r33 gts-t with flywheel spin, gearbox oil etc. etc. etc. for a total of $560 ... by ABS brake and clutch in Slacks Creek they r awesome. But i did bargain ALOT with them ... but they r good blokes, So yeah if u wanna go to them, tell them Bryan with the vandalise skyline recommended u ... and they'll do u good deals.
HEY!
This is an question that needs to be answered urgently.
I've been told that Nissan patrol clutch bolts up to my skyline by one guy (with 2300lb pressure plate) however another place told me that, that set up means that the plate engages really close to the floor.
Those of you who have this set up (including bryanlee and swordfish) is that correct? And if so how different to normal (is it engaged 1 cm off the floor with the rest of the pedal a waste)??
PLEASE HELP!
4 Doorz,
Now the Nissan Patrol Clutch is the same as any other new clutch.
If it's new then yes it will release early on the clutch.
My clutch is release about 2-3 cm off the floor.
Its not a hard clutch either.
My girlfriend drove it around one day and she didn't notice the difference.
I do recommend u speak to Geoff at Slacks Creek and Gavin Wood at Labrador.
He will tell u also...no different.
If u come to the skyline cruise on Sat I will be there and if u want u check the clutch out.
Not too brag or anything,
but I showed Gavin Wood at Labrador this Exedy Nissan Patrol Clutch from Slacks Creek.
So he knows all about and he fitted it on my car.
Tell him Gossy with the silver Skyline Gtst had u fit it.
I was quoted $572 fot a more stanhdard H.Duty Daikin, and $644 for an uber h.duty Daikin (SKR) that would be more suitable for my use...These prices are WAY over what you guys are posting. Why?
Thanks dood. I just skim sometimes, and so miss a bit. The prices I got were from Gavin Woods, but I'll dig and see what's available. I don't really understand the difference between clutches, compounds etc, so I'll end up getting taken for a ride :P
Seriously ALL OF U WHO wants to get NEW CLUTCHES - go to 'ABS brake and CLutches' talk to brett, he's awesome. I did bargain a bit but mine cost a total of $560 - EXEDY HEAVY DUTY CLUTCH INSTALLED (includes machine flywheel, gear box oil etc.) THey did a fabulous job, clutch feels awesome, AND IT COMES WITH 12 MONTHS WARRANTY.
BEWARE!!! MOst places if u buy a clutch and bring it to ANOTHER workshop to fit, they cannot guarantee the clutch, because they did not personally order the product. I was gonna do that, but ABS BRAKE AND CLUTCH match that price of me buying the clutch and getting it fitted. Better off now u can get that warranty
the clutch I'm using now feels great. its a tad shorter and heavier then the stock r33 gts-t one i had. CLoser to the ground thats about it. So far I've only stalled it once this week :D BUT ITs AWESOMe
ABS BRAKE AND CLUTCH = SAY BRYAN - WITH THE VANDALISE MAROON SKYLINE. and Brent (or brett) I cant really remember, he's the guy who will fix u up with an awesome PRICE. U may have to pay few dollars more, because i did bargain the hell outta him, and showed him my vandalise skyline kekekek. GO THE SAD STORY APPROACH!
cheers
bryanlee38
    • Rotisserie is fully assembled apart from centre connector which obviously isn't required until the car is on it. It packs away fairly neatly and doesn't take up too much room. (Now that I actually have some room after my clean up!) Overall very happy with the quality of it.  Assembly was a piece of piss.  The only thing I didn't like was that the pins that lock the rotation lock wheels in place were a bit of a dick in a bucket scenario. It allowed the arms to rotate a significant amount even when locked in place.  To fix that i measured up the hole and went and grabbed a couple of 18mm fully threaded bolts and a thread tap to suit. I ran the tap through top and bottom so it was threaded both ends.  Then just threaded the bolt through both sides.  It has made a massive difference which hopefully you can tell in the before and after video how much difference it made. 20250207_161431.mp4   20250207_161431.mp4 Hopefully back working on the car over the next few weeks.   20250207_162801.mp4
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
