My clutch is slipping, not when u engage the clutch but mainly from 2500rpm onwards.
Can anyone recommend a clutch to use and how much approx ?
(Genuine Nissan or other clutches)
Who do u recommend to do the installation?
Has anyone tried to take the gearbox out yourself if u have your car on jack stands ? (or do u need hoist)
Or leave it to the professionals ?
Immigrant performace at Labrador, Gold Coast quoted $930 for clutch and installation.
But Dane said the clutch they use is a heavy duty performace one they have designed themselves which can take 3000 pounds of torque.
Anyone have any experiences with this guy?
Mine Fried on Tuesday...Speak to Gavin Woods. He knows his stuff. Prices seem reasonable for Clutches. He has a couple of different options. Mine will cost me about 900ish installed for a Daikin (his recommendation)...
Call 07 5529 2313
As soon as I come up with the cash I'll be going in to get it fixed...
Michael
i got a heavy duty daikin put into my r33 gts-t with flywheel spin, gearbox oil etc. etc. etc. for a total of $560 ... by ABS brake and clutch in Slacks Creek they r awesome. But i did bargain ALOT with them ... but they r good blokes, So yeah if u wanna go to them, tell them Bryan with the vandalise skyline recommended u ... and they'll do u good deals.
HEY!
This is an question that needs to be answered urgently.
I've been told that Nissan patrol clutch bolts up to my skyline by one guy (with 2300lb pressure plate) however another place told me that, that set up means that the plate engages really close to the floor.
Those of you who have this set up (including bryanlee and swordfish) is that correct? And if so how different to normal (is it engaged 1 cm off the floor with the rest of the pedal a waste)??
PLEASE HELP!
4 Doorz,
Now the Nissan Patrol Clutch is the same as any other new clutch.
If it's new then yes it will release early on the clutch.
My clutch is release about 2-3 cm off the floor.
Its not a hard clutch either.
My girlfriend drove it around one day and she didn't notice the difference.
I do recommend u speak to Geoff at Slacks Creek and Gavin Wood at Labrador.
He will tell u also...no different.
If u come to the skyline cruise on Sat I will be there and if u want u check the clutch out.
Not too brag or anything,
but I showed Gavin Wood at Labrador this Exedy Nissan Patrol Clutch from Slacks Creek.
So he knows all about and he fitted it on my car.
Tell him Gossy with the silver Skyline Gtst had u fit it.
I was quoted $572 fot a more stanhdard H.Duty Daikin, and $644 for an uber h.duty Daikin (SKR) that would be more suitable for my use...These prices are WAY over what you guys are posting. Why?
Thanks dood. I just skim sometimes, and so miss a bit. The prices I got were from Gavin Woods, but I'll dig and see what's available. I don't really understand the difference between clutches, compounds etc, so I'll end up getting taken for a ride :P
Seriously ALL OF U WHO wants to get NEW CLUTCHES - go to 'ABS brake and CLutches' talk to brett, he's awesome. I did bargain a bit but mine cost a total of $560 - EXEDY HEAVY DUTY CLUTCH INSTALLED (includes machine flywheel, gear box oil etc.) THey did a fabulous job, clutch feels awesome, AND IT COMES WITH 12 MONTHS WARRANTY.
BEWARE!!! MOst places if u buy a clutch and bring it to ANOTHER workshop to fit, they cannot guarantee the clutch, because they did not personally order the product. I was gonna do that, but ABS BRAKE AND CLUTCH match that price of me buying the clutch and getting it fitted. Better off now u can get that warranty
the clutch I'm using now feels great. its a tad shorter and heavier then the stock r33 gts-t one i had. CLoser to the ground thats about it. So far I've only stalled it once this week :D BUT ITs AWESOMe
ABS BRAKE AND CLUTCH = SAY BRYAN - WITH THE VANDALISE MAROON SKYLINE. and Brent (or brett) I cant really remember, he's the guy who will fix u up with an awesome PRICE. U may have to pay few dollars more, because i did bargain the hell outta him, and showed him my vandalise skyline kekekek. GO THE SAD STORY APPROACH!
cheers
bryanlee38
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
