Hey im considering getting custom made piping say 2.5inch ..and buying a cannon muffler for my r33 gts
i dont know which would be best brand to go for..
i like Apexi N1 muffler but they are like $400..anyone seen them cheaper and from where
also X-Force mufflers i'll get 3-4inch tip and they arent to pricy
but with the x-force mufflers...are they any good..hows the sound they produce??
_______________________________________________________________________
UPDATE
ok ive tried searching a million times and ive emailed heaps of different websites to see if they sell Apexi N1 mufflers on their own and every place has stopped production on them and selling them...
i cant seem to buy any apexi n1 or hks super dragger muffler just on its own with a 2.5inch inlet
i dont know any other brands besides MAGNA FLOW & X-Force but i heard to keep away as they drone heaps....anyone know what i should do.....im only after buying a muffler as i'll get custom piping done if the current exhaust system im looking at falls through..
im looking for a cannon similar to the one below attached
thanks
Edited by blk_sz
https://www.sau.com.au/forums/topic/188789-i-need-a-good-muffler/
Dad has an Xforce muff.
He has one on his R32 Rb25DET VVL.
When we first started the engine and before all the settled carbon and shit build up in the engine left the engine, it made it sound like a bog block V8 WRX.. gosh it was freakon sexy!
The mufflers are quite loud and does create a fair bit of resonance and droneing. Some people get off on it, others take the muff off. What ever floats your boat really..
Its quite wanky and rice burner-ish. Its chromed, sticks out a fair bit (2 door R32) and has X-FORCE embedded within the top of so as you can see it from space..
Drove his car.. after 20min of driving, i was going CRAZY! it resonates and drones throughout all RPM.
btw.. it came with the car.. dads trying to swap me his muff for my NISMO one.. HA!.. (told him ill trade him my muff and stock suspention for his HSD coilovers.. not going too sucessfull)..
So theres your answer.. see if it floats your boat..
Edited by GTS4WD
ive updated the topic in 1st reply
im looking for a cannon similar to the one attached in first post
thanks
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
