I saw it, one of the first runs on Saturday.
The rear end wasnt tied down tight enough (I think) and the car moved forward and climbed the front wheel chocks.
It didnt instill me with any confidence in the dyno team, not sure what the final figure was for the car, but on that first run they only hit around 200kw (hate to think what could have happened if the car had lots of power)
200kw would be from wheel spin.. considering the car made 576rwkw
  • Replies 93
Posted Images
Doms rotor should have around 400, I have seen it run 360 with problems and I know there were a few dramas with the dyno over the weekend. I didnt see it run but I know there were a few complaints about the tie down situation.
Either way it was a good show all the same, with some great cars and bikes too. Would be nice to see some more hi tech representation next year tho....
Congrats cara for your trophies and dyno results,
Congrats also to SLED who had an amazing bike and a 34GTR at the show... lucky bugger. I was only told after the show that you were the same SLED on this forum!!
Yeah thanks Martin....I did check out your ride and the Sniper alongside yours, very nice.........would've liked to see you both pull a fuse and do a dyno run. The GTR's would've been a good crowd puller.
Congrats Cara & Pete on your trophies.
Pete - did you put the R34 GTR on the dyno?
Thanks Dave, would've been in it if they had a 4WD dyno..........I can't pull a fuse like a 32 GTR, I have to drop a shaft as well. :P
I would have if I wasn't working the whole weekend!! I ran it two days earlier at Southern Hi-Tech and had the dyno sheet on display instead.
R32 GTR... tuned at Southern Hi-Tech = 326.8kw at wheels (6/12/07)
Wow, I just notice the date on the fine print.......you gotta be happy with 326.
Congrats Cara, so what else do you have to do to make the magical 200rwkw you want (while still NA)?
umm...well the jets are actually 55 hp and not 75 hp which i origainlly was told ( i was given the wrong ones) sooo it would be a matter of getting my hands on that set and then doing a re tune to make sure everything is all good, and not running to lean or rich.....
but i have no more nos at the moment :P
and there is nothing coming up that i will need a full bottle for! (maybe in march/april tho when Debbie and Gary Myers come over for a one day event they were talking about at Gazzanats)
I would like to get some stage 1 or stage 2ncams in aswell as that will help with the n/a figure oh and a bigger fuel pump too lol :P
Yes pete, was very happy with 326.... I normally run 18psi which is just over 300 at the wheels but decided to wind it up to 21psi and see what happened!
I do have a few upgrades on the RB tho... :P
Cool.......have to catch up some time and compare notes.
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
