Hey all,
Just read Motor's test of the new Evo X. I was quite shocked to find out that power is to remain at 206 kw while torque increases to 422nm from 400nm.
They did some rough acceleration testing (to the dismay of the Mitsu officials) that showed that it was very similar to the previous Evo. All the technology has been retained and somewhat improved.
There was a lot more to the article however in summary it seems as though it is not the revelation I was expecting. Sure the appearance has changed for the good however with the added weight and no more power performance is expected to be retained at Evo IX levels. I am no Evo fan but do acknowledge the cars to be amazing performers.
I am personally disappointed and so too will enthusiasts in my opinion.
https://www.sau.com.au/forums/topic/188859-motors-test-of-the-new-evo-x/
After seeing one in the flesh, i think they look great. It's the same with the new WRX though, No power upgrade. It will be interesting to see who runs them in Targa Tas next Year.
I was thinking the same. At the moment it is the Evo that is the weapon of choice however with the increase in weight and the decrease in the WRX's weight (assumably the STi will follow suit), the tables might turn.
yeah more power would be good. but evos already run very high boost from standard. 1.2 or 1.3 bar from memory.
Motor tested them they were up and over 18psi at full boost. Quite a lot for a factory car.
I thought they would do more for the Evo X, maybe they are saving it for later models of this shape? I do like the new look of it though, much preferred to Subaru's attempt at changing the placement of the product.
I wouldn't base my judgement of the car upon just one source of review. Look for reviews from Japan or the UK motoring press. And don't worry about the power output just yet Mitsubishi always bring out the light weight, boosted versions soon after.
Were they any remarks regarding the twin clutch system?
Yes the test drove the twin clutch system and spoke very highly of it.
In relation to your remark about them bringing out boosted versions later, does Australia get these or just the UK? I always thought we received just one version.
Getting power from an EVO is so bloody easy i agree with 666DAN, 206 kw WTF, the reason why they run so much boost because the cams they use are so restricted its not funny to meet emmission laws, you put a set of cams in an evo with FMIC, exhaust, ecu, you have an 11sec weapon, my mechanis has the evo ix and with ecu only tune that he did he went and ran a 12.8 1/4 at eastern creek so shit all factory just an ecu tune with existing car.
no power??
that can be easerly fix
It's true, and an interesting point, it's the most discussed topic with regard to new performance cars, but if the hardware is right probably the easiest fixed too (Japanese gentleman's agreement proves that this era).
2 things...why do Mitsu stick with the old J-Gov bullsht 206kw rule when it has been phased out and then make the new car 100Kg heavier...fo fk sake we need a 240kw Evo if its going to weigh 1500 porky Kg's
1500kgs is GTR territory and that is where we are headed with cars which that size used to weigh 1200kgs.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
