It doesn't matter how fast it is, you'll still feel like you are driving a park bench. Magna's driving position sucks
you do know that there are levers and stuff that let you adjust the seat (both the angle of the back rest and the lower half of the seat.....
people always say 'i did it to be different' 'no one has done it' etc.. the reason no ones done it because its so fkn retarded
bahaha... quite quotable
Pull that engine out and fit it in an AWD Manual model and it may be a different story.... :P
STILL WILL UNDERSTEER LIKE A CIVIC
RPW are so good at what they do that their achievements are even discussed on a high and mighty Skyline forum.... :|
How many of you posting have run an 11.9?
Didn't think so...
But Spirro works on his Torri from the back of his fish and chip shop and can run an 11.8, but I'm not impressed. You can run any time in any car if you throw enough money at it.
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
    • lol thanks for the pics but some arrows might have helped for context. If you mean the bit I've badly traced in red, that is a PITA vacuum signal for the power steering pump, only R34 GTT was "lucky" enough to get it. Yes you will need a nipple of the same size somewhere in the intake between the air filter and the throttle or the power steering idle up will not work correctly
