Hey there, if anyone has 19" wheels on there R33 GTS25t I was just wondering how it effects the cars performance as in handling & grip etc..
I'm concidering purchasing a set of 19" rims but I'm worried about scrubbing, rough & bumpy ride, excess stress on bearings, bushes etc.
My car is a daily driver so I want it to be very pratical & not unberiable to live with day in & day out.
Currently I have some 17x7 with 235x45 bf goodrich tyres on stock suspension & the car is just fine as a daily driver although I could go a little bit tighter on the suspension. If anyone could give me feedback it would be greatly appreciated.
Cheers
https://www.sau.com.au/forums/topic/188878-19-wheels-for-r33-gts25t/
I had 19's. THe ride was a tad rougher. Nothing to write home about
Right about the tyres being super expensive though for anything decent. Didnt relly notice a different in handling and it wont scrub if you get you measurements right.
"How will 19" wheels effect performance?"
negatively. more unsprung weight means poorer handling, worse acceleration and the standard suspension will have trouble controlling them nicely. of course they are also illegal. personally I think it's a bad idea all round, but if you must have 19s for some reason then go for it. I mean it's not like your whole car will fall appart instantly, but there are certainly negative effects.
What do you recommend to be the best set up? 18's?? Keep in mind I was considering upgrading the suspension but this brings me back to what is the ideal setup for grip and street use? I'm not really interested into turning my car into a drift machine I'm more set on having a responsive grippy package so the car is more of a pleasure to drive.
I have found some places in the U.S that will sell & deliver 19" tyres or most size tyres at a more than reasonable price, since the oz dollar is so strong the US prices are hard to look past.
na... wont hurt. i had 17inch volk rims with stock struts, stock suspension and stock compressed springs and i have upgraded to 20s. hasnt in anyway affected the cars performance or handling, but it would pay to stiffin suspension with some shorter shocks and sport springs, car tends to scrape the inside of the front wheel wells when hitting dips on the road. also when putting rims on the front you wouldnt be able to slide a piece of paper between the wheel and the struts hehe!. 19s should fit no problem in the back and as far as the front goes selecting the size of the tire will determine if you will scrape on the inside of the guard knowing you have stock suspension gears...
I would go for a 245 or maybe 235, 35 profile for the front. I was looking to upgrade the suspension with something a little stiffer and just a tiny bit lower but I still want a comfy ride. I think there is more to gain from installing thicker swaybars and strut braces and trying to reduce the roll. Does anyone know what is a coil over that is good for road use?
Does anyone know what the correct offset for 19" wheels are so that there wouldn't be any issues?
If 245 were too much for the front then I would go 235. I currently have 235 on my 17x7 at the front and these have no issues what so ever.
i got no issues with 245 on the front. The 33 guards a quiet big to fill. i can full lock no probs, saying that though.. if a hit a nasty( real nasty) bump it scraps a tiny bit, but nothing that is of a real concern.
Edited by jake33
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
