hey people......
Well i have A stock R33 with these basic mods.
FMIC,
3inch turbo back,
bosted to 12psi on the switch, 7 without.
Pod filter with UAS air box
Turbo smart BOV type 2
Extreme button clutch
S AFC = coming soon
Now i want to advance Timing what do you guys reckon it should be set to
and what have set yours too?
thank you in advanced
https://www.sau.com.au/forums/topic/188905-advanced-timing/
ive got a r34 and the timing is super advanced .. wtf its like that i dont no .. pulls like a bull on roids tho :) (
yes indeed ............mine is a bull on creatine....
i want a bull on roids
https://www.sau.com.au/forums/topic/188905-advanced-timing/#findComment-3405850
Base timing should be left at the factory 15degrees and a tune should then be done to alter any timing settings under full load...
so practically just wait for the SAFC then start talking
https://www.sau.com.au/forums/topic/188905-advanced-timing/#findComment-3405882
i'm not sure how an safc is going to what you want it to do, unless they have changed and now they timing but as far as i knew you could only change air flow meter signal, so to change timing you would be changing base timing anyway.
https://www.sau.com.au/forums/topic/188905-advanced-timing/#findComment-3406315
+1. safc cant change timing, only an air flow signal bender.
https://www.sau.com.au/forums/topic/188905-advanced-timing/#findComment-3407551
