Coolant For R33 Gtst
dnbutts
 Share
The green one!
Nah... anything decent-brand with corrosion inhibitor. You probably don't need anything with antifreeze, which narrows it down a bit.
Castrol, Nulon etc... If you're doing a complete flush, you shouldn't need to worry about mixing different brands, and you can start with almost anything you like. (and you'll know what you can top it up with after that)
Im looking for coolant hoses and the like. My R33 needs basically a full new cooling hose kit. Do any of you have anything I can use?
(I don't want to pay $700+ through Nissan if I can avoid it)
Cheers,
Josh
i heard to only use genuine Nissan coolant also by mechanic. i never was told why the other brands like castrol etc are no good and If they would or wouldn't cause damage??? its interesting because iv always used non genuine coolants in all my other cars and hadn't had a problem.... are the skylines different or more sensitive?
www.gimmecarparts.com.au
Contact James. I got the upper and lower rad hoses for about $60
Nothing wrong with the Nulon green stuff. I get the concentrate 5L for about $35.
If you want to be anal you can get distilled water. I just use tap water and do roughly 40% coolant to 60% water.
+ 1
I have used it in all of my cars to date, even my dedicated drift car which gets a thorough workout to say the least. Never had a drama. Not much less than the nissan coolant though, so i spose if your a bit anal about your car maybe its worth a shot
There's 15 is there?!! - Is that including power steer etc? I did all the coolant hoses on a rav4 recently. I think there was about 5 hoses all up.
Maybe some of the smaller hoses you can just use standard hose and cable tie it to rigid parts to give it the shape. I didn't think there were that many in the R33
I got all the rav4 hoses for about $70 or $80. Check
http://www.mackayrubber.com.au/all-catalogues.htm
Can order through the other link in my previous post.
  • 1 month later...
 Share
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
