  • Replies 49
well the plans at the moment will probably be a different exhaust and a Motec M800
Oh dear... :D
What's wrong with the current setup??
Installing a motec will devalue the car....
Don't forget there are only 20 of these in existence...
I've had the pleasure of seeing this car in the flesh at Racepace, and always hoped that the lucky bastard that buys it keeps it the way it is without raping it.
I'm shattered....
My numbers still haven't come up so I guess I missed the boat.. :P
https://www.sau.com.au/forums/topic/188932-r34-gtr-z-tune/#findComment-3406208
I was talking about this car the other day. Wish it was in my drive. Having said that, it would never leave the drive and would live in a blow up protective cover.
i would leave it standard, buy a gtr thats not a z tune to mod.
Edit, Please PM me the link to pics when you get the chance. :P
Edited by BNR32t
https://www.sau.com.au/forums/topic/188932-r34-gtr-z-tune/#findComment-3406229
did anyone miss this... "427 monaro". nice! your dad has some taste mate, and lucky for him some cash to back it up.
nice garage. 427 monaro and a Z-tune. easy meets west in limited run 'tuner cars'. It's a tough choice as to which one I'd have though. the monaro or the GTR. I mean, I love the z-tune, but the 427 is a pretty special car too.
https://www.sau.com.au/forums/topic/188932-r34-gtr-z-tune/#findComment-3406978
Yep - before you go wrecking it with an M800 go and speak to Ben at Racepace who knows that car as well as anyone and have a chat to him about it.
Infact if you also want an exhaust go and speak to him. Best GT-R exhausts around. :)
https://www.sau.com.au/forums/topic/188932-r34-gtr-z-tune/#findComment-3407225
You're going to be changing a Z-Tune's exhaust?
You do realise its a full titanium system worth a boat load of money right? The last time I saw one sell it went WELL over $5k at auction (500,000++yen).
It screams bullshit that anyone would even consider this.
https://www.sau.com.au/forums/topic/188932-r34-gtr-z-tune/#findComment-3407933
Well my theory is its still his car so he should do whatever he wants to it. And if hes going to change stuff, at least it looks like hes not going for China gear.
But having said that, its true, how can you top a full titanium Nismo exhaust? :cool:
https://www.sau.com.au/forums/topic/188932-r34-gtr-z-tune/#findComment-3408757
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
    • 40 grit sounds about right, to start. You make some decent cuts/damage in the coating with that, then rapdily scale up to maybe 80 and 120 for the bulk of the actual removal, then fine it off to 180 or 240 perhaps. No need to go any finer than that, and maybe no need to go even as fine as that. Wrap it on a big block and have at it. At least on the hub face.
    • Do the GKTech rear lower control arm mount relocation, and either alloy subframe inserts or very stiff subframe bushes. Traction is going to be at a premium!
    • Hello,   My name if Frederick, i'm 30 years old and I live in Belgium, Europe! I used to have a Nissan 370z daily but since I got a company car I turned that into my seattime driftcar. About 3 years ago I also wanted something older with more feel, so I got an R32 GTST with an rb26 engine. I am now getting the rb built to have around 800hp and it's close to being finished. I'm very excited for how it will drive and how driveable it will be! Regards, Fred!
    • Appreciate the insight! Talked to some local folks and they basically told me "it's not that deep." As long as the threading on the inside matches what's at the steering rack, everything else can be constructed-to-fit. There are full aftermarket kits I can use - probably better for my car overall since it's lowered.  Example: GKTech M14 Super Adjustable Inner Tie Rod Set - Nissan Skyline R32 R33 R33, 240SX, 300ZX, 350Z / Infiniti G35 M14I-TROD-2 gktM145-TROD gktM14I-TROD - Concept Z Performance (These can be packaged with their "high misalignment" tie rod ends).
