^ lol
Thanks for all the advice and info guys... hopefully mine dosnt end up in pieces in a gutter somewhere but theres only one way to find out :D
u know u can just buy that front lip yeah dude.
also if use need carbon stuff made speak to shane from psi parts, hes a top bloke, where about to embark on a full carbon overhaul of my r34 coz the shit that u buy from flamin mongrels these days is just f**king shit quality ...
whos sells them ? ive looked everywhere are they local not a real fan of buying from OS
Edited by Hiroshima Screamer
you have a point about it being impractical but i thought id give it a shot anyways...
looks the goods...
I made that lower lip. It does look very good, but driveways are a carbon lips worst enemy.
"Noy" on this forum is a Brisbane bloke, he too can make ze custom carbon stuff.
Works in aerospace.
He's currently working on 34R replacement panels in ze carbon.
And alot of R32 stuff too...
Here's another pic of it.
nice work there mate looks awesome.. whats something like that worth delivered to Sydney and how long would it take?
PM sent
thanks mate ill have a look.... once pm are working again :dry:
LSM Composites in QLD also make fantastic carbon items.
This is the roof scoop (which is for sale ;) ) that they made me. The quality is outstanding, unbelievably good.
very nice finish on the scoop
Hey Noy,,,can you supply flat sheet carbonfibre???.
Cheers
Neil.
Yeah I can, What size are you after?
LSM do great work. gotta love that 4x4 crows foot carbon. Most of the V8 supercars cosmetic parts are made with it, so easy to work with.
  • 4 weeks later...
+1 on that buddy, what sizes can you get ?
  • 3 weeks later...
    • Is anyone running these axles? R32, R33, R34 GTR front Axles. shafts itself rated 950hp. Suit all RB26 engines Croydon, Melbourne, Victoria Would be nice to pay half the cost of Driveshaft Shop Axles. I'm building an AWD S13 Coupe that is very low ride height (high cv angle) compared to stock R32. Has an RB30 with appx 600whp. Just looking for feedback. Thanks, Josh- https://www.instagram.com/feng_shui_garage/
    • Been a long time since r31 got some love, my brother dropped a shitbox ls1 crapadore in my lap to fix up.  Put a wiper motor in as the flooded one was no longer alive.  got windscreen wipers now. Time to clean respray and install back in the titanic  IMG_0505.mov
    • Nah its a server spammer thing  Although, now that I manually approve all the accounts I can probably loosen up some of the restrictions.
    • Thread bump, again! Although, no bad news this time. Posting for the sake of possible root cause. Basically, I rebuilt it (mostly stock), installed Haltech + sensors, had it running fine on new ECU.  Still not really understanding why it cracked pistons last time. Got to tuners, and while checking timing, noticed +-10deg of timing scatter while revving. Changed CAS, and it was rock solid. While not definitive, can't imagine seeing 20+ psi with that amount of scatter would be a good thing. Also glad I found something.   Bit more of a run down; Carried out a stock rebuild, a set of stock pistons, out of a spare bottom end. Everything stock apart from head studs and oil restrictors. (so I can pretend I didn't let the Nissan out, ha.) Armed with the measuring gear and FSM, set about doing overhaul. Oil restrictors as per oil control thread for a RB25, stock oil pump, drifting. Head drain/vent from rear of head, to passenger side of sump above oil level. Two dash 10 vent lines from drivers side of sump (unused atm) Hi octane style cam cover breather kit Splash covers over last 2 cam caps. Both breather lines from cam covers to vented to atmosphere catch can, not plumbed back into sump (wanted to see what it was actually breathing). Got it run in (did about a 1000km) no to low boost scenario, As I had questions over old ECU setup. Installed haltech +sensors for flex Retune on E85 (finding CAS Issue along the way), made 300rwkw at 20psi, out of wastegate. Did a drift day the next day (yes, it was a big weekend!) and was checking catch can throughout the day, ZERO blowby. I mean nothing. Lines from cam covers are not even wet. Done a bunch of street driving, spirited and catch can is still dry. Early days I guess, but pretty happy so far. Also now run 10w60, up from the 10w40 that I used to run. Oil pressure is significantly better, especially when hot (as you would expect)
