Whats the best way to polish a dished wheel? Ive got some Rays wheels that i want to paint the centres black and polish the lip, ive started using 1200 grit and brasso in a small section on the dish and its coming up smooth, but dull... how do i get the shine?
anyone recommend what sort of prep needs to be done for the wheel centres also?
cheers
i had my 4 stockies, sand blasted and powder coated for $180 the lot. about 45 per rim. in a pearl white. if u just getting centres done might work out cheaper.
with polishing, get a metal polish and use that. dont fuss to much with sand paper unless there are scratches all over the dish.
hey mate i just did the four of mine.they looked shit house and now there unreal.
1.clean rims.
2.wet&dry sandpaper 1000 until smooth
3.wet&dry sandpaper 2000 which takes away some of the lines that the 1000 left.
4.clean rims and use autosol and elbow grease your way to pretty good looking dish
doing just centre would cost you more, since there is more work involved in masking up the lips, then blasting then remasking them for the application of powder
simon-r32 - looks good mate
is there a place i can take my rims to.. to do something like that?/ repaint the center and polish the dish again as mine looks really.. dirty
and i wouldn't have a clue of how to do it myself...
in vic as well..
just curious as to the difficulty of it, my Works use a bolt head that i havent seen as a bolt head before.
wasnt an Allen key or Hex head was it? Most are like this.
Its easy enough to pull them appart, most rims have a sealant (3 piece ones anyway) in the middle, and also when re assembling they need to go back the same as you pulled them apart to keep the balance of the rims the same.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
