You guys realise he already has the engine, so there's no point trying to push your opinions on different engines.
you wanna do this as a fun project, and somethig different go for it! But keep the carby i recon... :down:
Thats right wana see how it would go i havent heard of anyone with the old school 302 in a 32 yet so should be fun. Yeah im thinking of keeping the carb at the momment and as for the 25 in it mentioned later thats been done before and the custom work wont matter as me and the old man have done custom before. also i already have the 20 and the 26 so time for a different spin on the nissan
Edited by dmac_25
I was thinkin of doing that with one of the new "aluminators" aluminum block 4.6L ford and twin turboing it. Imiagine what it would be like when you punch it at 3000rpm and before it gets to 4000rpm your torque jumps to arround 800 and stays within 50ftlbs of that through the revswith over 1000hp. An R32 to me sorta looks like a 88-93 Mustang but was way nicer and wont twist the car with the stock engine. You just gotta keep in mind that the 5L engine is only good for up to 450hp in good condition but the 4.6 can be pushed to arround 800-1000 absolutely bone stock with the fuel and spark and air to produce that so if you want a high performance machine find a 4.6 out of a 96' + (has to be over 96' or dont bother) and then throw in some 3 or 4 valve a cylinder heads and you'll be ready to suprise a few people.
Though if your not going for high hp then a carburated high compression 302 with a rhoudy cam would be really bad ass to hear that carburated rough idleing v8 under the hood. Hell i was thinkgin of doing the opposit some day and matting a r34GTR tranny/transfercase into a 96-03 mustang make it all wheel drive and twin turbo or Kenne Belle (Kenne Bell or nothin) supercharge it so i'd have pretty much the best of both worlds on street tires.
Hey mate,
I was thinking of using a late model engine either AU xr8 or the BA xr8 engine but as ive already got the 302 floating around mite as well use it i found a supercharger kit for a carby 302 i was only aiming for the 500hp mark outa the old girl wouldnt need much more in a striped out gts as a drift pig.
Would be different hearing the roar of a v8 in the good old 32
Like most engines the modular 4.6 needs a large wad of cash,work and bits thrown at it to make 1000hp. Bone stock isn't a term I'd be using to describe anything but a hand grenade at 1,000hp. If the thing hung together for longer than a week then I expect the main web and bulkheads are going to be cracked quite nicely in due time. Those factory blocks aren't what I'd be starting with for lots of power.
There is no magic brand or type of block that makes 1,000hp cheaply in a small cubic capacity. Thats the rule. The blocks best suited to it are race blocks, usually billet if we are talking 1,000+ hp.
    • Listening to an artist called "the flashbulb". Not bad. Makes some fairly well researched youtube vids in various things.
    • Is actually easier than you might think. Assuming you have a spot, youfab up the branch, then just hang a longer than you can fit length of pipe down from there, and chop bits off piece by piece and decde which length was the quietest/nicest, then just put that length up in the place where it will fit. Clever folk can actually make like a trombone slide type arrangement so you can just play it like an instrument to find the best length.
    • Buy her some ear plugs.   Or, wear earplugs so you also can't hear Jackie whining...
    • Necroing this thread in 2025 to say thanks! The Manual for the m60 still has the wrong instructions and says to only press button 2 with ignition on. You are a champ, thank you.
    • Night Fury is still going strong. Just added a few recent pics. I have a few projects lined up so stay tuned - I plan to breathe new life into this thread soon!!
