[i:d7df653a5c][b:d7df653a5c]CAR[/b:d7df653a5c][/i:d7df653a5c]
1992 HCR32 GTS-T
[i:d7df653a5c][b:d7df653a5c]MODS[/b:d7df653a5c][/i:d7df653a5c]
Cat back 3.5" exhaust
14.7 PSI
HKS Pod Filter
[u:d7df653a5c]POWER 117RWKW 2ND GEAR[/u:d7df653a5c]
Turbo back 3.5" exhaust
12.6 PSI
BLITZ Pod Filter
Front Mount
[u:d7df653a5c]POWER 168RWKW 2ND GEAR[/u:d7df653a5c]
14.8 PSI
BLITZ Pod Filter
Front Mount
S-AFC
Fuel Pump
[u:d7df653a5c]POWER [b:d7df653a5c]206RWKW[/b:d7df653a5c] 4TH GEAR[/u:d7df653a5c]
*After 5 hours on the dyno I was VERY happy with the 206rwkw
*I was unable to tune my cam gears so back to the dyno next week.
*It appears that the airflow meter and injectors may be maxed out.
https://www.sau.com.au/forums/topic/189-boostmeisters-power-up-journal/
Yes Steve time to post on SDU, I'm not a show off but I think they need to know that us Ozzy's can build quick cars too.
ONARUN, There is very little point in fitting a reg as it will only help a bit and in the long run I will need bigger injectors to support a big turbo etc, is is only a band-aid solution where as a quick opporation will have it sorted for good not to mention that a good reg is $400 which is probably around 1/2 of the inj. price.
Steve, what injectors will fit in my car? What size are they now? I have heard conflicting report.
Cam
How much difference is there between 2nd and 4th ? I'm guessing this is just the peak power output ? Cause I definately find in my car that it pulls hardest in 2nd also. I havn't put it on a dyno yet but it's just my observations from driving. It's only got a 3 inch cat back.
Birty
Its really weird actually, when I had 168kw I made that in 2nd but in 4th I only made 160kw. But now I make 189kw in 2nd and 206 in 4th so now the power range has changed? We have tuned the afc really well for 40% throttle and it pulls so hard, the torque increase massively
Well it's good to hear, i'm still trying to get used to driving my car. But I will look about slowly upgrading it. I really think 200rwkw would be heaps, but I wanna get used to the car a bit more. I've got a cat back 3inch (I think, might be 3.5, havn't really checked) and am thinking about getting a 3.5 inch dump and front pipe in the next few months. Then eventually upgrading the rest (although i love the throaty sound of the one on there). Or would it be better getting a Front Mount First ? And have you see any good cuts on the m spec bar ? As I'm not too keen on buying another bar mainly for the risk of going to low and being a prick to get around in. Plus if I get a new bar, I wanna get new wheels and springs and do the whole lot at once.
  Quote
Cam[/quote:b2593e2f85]
Cam,
A decent rising rate reg' (as used by a number of 10-9-8sec 1/4 cars) is less than $400!, try under $200. Add a decent pump to handle the xtra demand place on it by raised f/press' & you can gain 20-30 or more rwkw quite safely. This exact same method has been done on GTS25t's on more than a few occassions. I'm not talking about huge f/press' & rwkw increases only mild ones. Of course the RB25DET 370cc inj's are able to flow far more than the RB20DET 260cc'ers, & in your case it's getting to the stage where even with raised press' it's maxed out anyway.
Have a read of the f/press' run by the Gibson Motorsports prep'd ATCC GT-R's in the early 90's, upto 138psi!!! & 470kw on 550cc inj's. In full race trim they sure pushed those 550's pretty hard! It'd take a decent pump to cope with that kind of demand 8O .
My reg + pump installed & fitted was much cheaper than a full inj' / pump etc.. upgrade!!! Sure you can probably reach 300+rwkw once you go 550's & bigger but you'll be looking @ strengthening internals before that stage anyway!!!
Righty O yeh I agree now......I just had another look at my dyno chart and discovered that I am not running lean at the top end at all, I am actually running super rich....DOH, thats what happens when a "Friend" tells you the results without actually looking at the af chart (Originally I only had the HP chart with no af graph)
I have a big mother of a pump (Bosch 044) which actually builds pressure as the power increases :) My tuner has tried to lean it off but for some reason the s-afc will not modify the fuel at full throttle ? I also found out that my afm is almost maxed out at 95.9%
[img:c2903fdbd6]http://www.d-u-e-l.com/dyno_chart.JPG[/img:c2903fdbd6]
See there ya' go! Into the 10's (A/FR) @ peak power mate!!!
You've still got power to come!, once you lean off those peak power mixtures :) 300rwhp. The 044 can handle 300rwkw so you can lean on it a fair bit with xtra pressure, but the inj's can only take sooo much.
And thus, continues the saga...the Z32 and the RB20det afm's are the same size! only the Z32 has a different amount of pins and it reads the air flow differently.....I am still trying to find out exactly what the difference is however I am really starting to consider ditching it all together or moving it into the fmic piping!
    • That idea has crossed my mind, I do a 5km walk everyday, this does take me past some bushland......I think you may be onto something 馃槈  That, plus 1 rock on every bin night might do the trick, it may take a year, but it could save me a couple of grand The only issue is the big 'Boonies", I have a few that weigh around 30-40kg, maybe they should be the first to go into the raised garden bed,  and then let the next owner deal with them....my daughter gets the joint when I kick the bucket, mums the word mate......LOL Noice......
    • Wow. Did you call the car a Nissan Skyline?
    • You're retired Mark, on bin night, go for a walk, kind of like you're doing the beep test. Put one rock in the first neighbours, come back, get another rock, go to the second neighbours, repeat over many weeks. All rocks eventually gone...
    • No chop chop of anything mate, it is what it is, plus, I don't want any air that isn't either going through the cooling stack or intake getting into the engine compartment increasing under bonnet pressure  Yeah, the Mazda Speed aftermarket intake above is less than ideal for multiple reasons, the requirement to remove the bumper every time you need to service the filter, and also smaller in diameter than the NC1 OEM one Weirdly, Mazda Speed is part of the Mazda motorsport division, "form over function" and $$$$$ for Mazda from unsuspecting punters I suspect  After some googling about them it seems they added no power, but do increase some induction noise Meh In other news, the electricians have been busy today at the house, and are back tomorrow finishing up all the security stuff and exterior lighting, they also added some lighting on the garage ceiling, which will come in handy when working in the garage when it's not freezing out there My Birdies raised garden bed also arrived today as well, which I'll put together and place tomorrow, it's a big tall Bessie, 74cm high, 92cm wide and 214cm long, this will come in handy as I am starting to get "stockpiles" of good soils from doing landscaping, some of the clean rock, namely the river stone, will go into the bottom of the bed for drainage, as well as the old Apricot tree that was out the back,  and when it's full, I'll grab another one, I will be growing enough veggies to keep me both busy as well as supplementing the shopping list I'm also awaiting another quote for a new Colourbond front fence, as the "1980 style cemented in rock edging" that was there and "fashionable at the time" looked arse, and my god, the amount of cement used to fix the rock was insane, it took 1.5 days for me to break out 12 meters of the stuff by hand, trim the bushes back to the fence line and dump it out the back of the joint to deal with at a later date,I will soon need a skip bin to tip it all Unfortunately they did alot of the cemented in rock around the joint, which I hate, so a few pallets of retaining wall blocks for around the front and back where the cemented in rock is will be required to bring it up to a standard, and look, that I will be happy with 12 meters worth of rock and cement Finished smashing the fence line and ready for a fence to be installed, yes, the lawns need some TLC and thickness, the previous owner trimmed the grass to the roots 馃槩, the TLC I can provide, and nature over time will do the rest And there's probably about another 40 meters worth of this landscaping abomination left to do around the front and back gardens, I'm guessing maybe 3 or 4 tons worth, tip fees for this will be a killer Meh, all in all I'm having fun and keeping busy, plus, it's good PT
    • If I drove to a typical petrol station, what would my choices of fuel be?
