had a 180sx before my first skyline, so either still driving that, although, by now i'd probably will have upgraded to a JZX100 chaser or JZS147 aristo. depends if i wanted fun or cruisy.
  • Replies 64
well technically if the "skyline" ie prince skyline didn't come around, DOHC engines wouldn't have been popular in japanese cars.
we'd all be driving around in the descendent of Isuzu Bellett GT-R's (came out 6 months after the first Skyline GT-R)... ie... Gemini's.
It was between a S8 FD RX7 and my GTR, so that makes the answer easy. I have had so many different types of cars not having the GTR to choose from wouldn't have mattered in the grand scheme of things, but the GTR is still my favourite car when it comes to driving regardless. :)
your cefiro wouldn't have an RB20 then... you'd have to do with a CA18i or some shit like that.
Thats based on the assumption that the RB range wouldnt have come along without the skyline. Hell if it wasnt for skylines they might have made a BETTER engine!
Damn it, you skyline people are bring my cefiro down!
lol i own a ceffy too. well the R31 brought the NICS RB engine around, along with the 200ZR Z31... then the ceffy's got an improved version (sorta like an R31 RB20DET with ECCS)... then the R32's got an improved version of the ceffy engine.
the price of right ahnd drive conversion alone! arghhh!
i gota buy the misses a yank tank stang anyways...
meh.. i bought the line for bang for buck.. ie.... the hole braking handling go package that didnt look fugly for my price range!
Im guess most will.. else id prolly be running around in an awd turbo econo box
Nice! i reckon you'd be able to fit an rb motor under that bonet! ;) might be a bit of a squeeze though.
now i think of it i wouldnt mind a series 8 rx7, i love the buzz from the 13b! :P
would probably go a 2JZ instead of an RB in that car, cause they use either 4AGEs or 2ZZ engines... so it would just be easier ;) IF it were to fit... would probably have to lengthen the chassis a bit...
Well I don't have a Skyline, but it would affect me as the RB30 would not exist.
Therefore the best engine ever to go in a Commodore would not exist, and Holden would've got the 3800 and placed it into the VL before the VN.
Oh the humanity. :P
Thank f*** for Nissan.
Edited by RyanVLSL
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
