Well I got my 180-sx after long debate. Yay me and hello skyline owners. Im sure ive seen a few of you around the northern beaches in your skylines just today I saw a white 34 parked collaroy just past a round about heeading towards traffic lights (not gana be particular due to rising theft rates) and a maroan(*spelling*) skyline at a set of traffic lights with black rims from memory with maroan lining on the outter. Anyways HELLO SKYLINE OWNERS! im TOM! :)
Edited by tomk
From now on, whenever I will see your posts I will here Troy Mclure in my head.. but with a slightly westie accent cos you said "yous"
"Some of yous might remember be..from such threads as I Need Help Choosing The Right Car For Myself and Second thoughts!
oh and welcome.. back.. to the forums.
Hi, I'm Doof... so what colours your skyline? :dry:
heheheh I own a:
180-sx 93 5 speed SR20det :P you guys are gana hate me lol i need to update my name info ey hahahaha.
its a great car though enough power for me for now. :)
Though in around 4 years max im considering purchasing one of the skyline GTRs eventually. and then after that (fingers crossed) a porsche carerra Gt :laughing-smiley-014:
Edited by tomk
ive since ripped the spoiler off guys it was bubbline still need to get the holes welded shut smoothed over and resprayed along with a light surface rust on the side door but meh plenty of time to get that fixed :laughing-smiley-014:
Edited by tomk
heheheh I own a:
180-sx 93 5 speed SR20det :rofl: you guys are gana hate me lol i need to update my name info ey hahahaha.
its a great car though enough power for me for now. :w00t:
Why hate? A 180SX is better than most cars on the road IMO
EDIT
4 Stud aside, I like your rims :)
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
