hey all
been installing a set of defi gauges.
when the ignition is on or car is running, i set the warning levels and the next time i start the car the waring levels have been reset.
it seems the starter motor cuts the power to the gauges..
i first wired the constant power wire to a 12v wire that goes to the ignition barrell. then i tried the constant power one at the back of the CD player.
anyone know what could be causing this?
thanks,
luke
https://www.sau.com.au/forums/topic/189048-simple-eletrical-problem/
you must have the wrong wire then.
get the constant power from the radio, thats the easiest. do a test:
wire the constant and "ignition on" power wires to the what you THINK is the constant power wire. if you are right and it is constant power feed, connect the battery and gauges should come on even without putting the key in. if they are off, you were off :thumbsup: and try the wire you were using as the switched power feed.
constant 12v is usually a yellow wire from an aftermarket cd player, switched power is the red one. constant meaNS STRAIGHT FROM THE BATTERY, without the ignition switch inbetween. this is the memory for things like the clock and stereo.
elsewise, run a small cable straight from the battery with an appropriate fuse, this is the foolproof way
yeah i tested the wires with a mutimeter b4 i connected them.
the second one i tried is from the yellow one at the back of the cd player.
im thinking maybe my battery may be too small?
yeah next thing ill try is to run a wire straight from the battery and see if that works.
and if i set the memory then turn the car off, then the next day turn the ignition on, the memory is still set until i actually start the car up.
edit**
problem found.. changed the ground wire and problem solved.
Edited by luke20t
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
