Its always interesting to read these sorts of threads.
For me. No doubt the GT2. Friends who have driven the F430 all rave about it, but i just dont get it. At most revs it sounds like a 4AGE Corrolla, having driven a few of those flippy flappy gearbox cars they dont do it for me...so yeh. GT2 is an easy choice.
Plus, ever heard the saying better dead then red ;)
i prefer the regular gear shifter too...
but which cars have u driven with the paddle shift gear boxes? a 599gtb? gallardo? an enzo?
or do u mean uve driven the cooper S paddle shift? :)
