R32 For The Track
Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank. -
I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
